Author Topic: 70 Auto console shift button popped out  (Read 700 times)
Offline tman
« on: September 04, 2011 - 10:55:44 PM »
All, as I was leaving a car show, I pressed the shifter button to reverse and the button popped out.  What the heck keeps it down?  Had to take the spring out so I could still shift it.  Is it the set screw that keeps it in?
or is it broken?
Thanks for the help.
Offline Strawdawg
    • Vortex Buicks
Re: 70 Auto console shift button popped out
« Reply #1 on: September 05, 2011 - 01:08:27 PM »
Isn't it threaded onto the end of the cable?
« Reply #2 on: September 05, 2011 - 05:40:32 PM »
I think the spring just screws in.
Offline quapman
    • Auto-Grip on Facebook
« Reply #3 on: September 05, 2011 - 07:15:50 PM »
The button itself is threaded and I believe it's keyed to the outer knob. To install, spin the whole enchilada with the set-screw loose, then when you're to "depth", tighten the screw. The threads might have stripped since the button is only plastic and it's 40 years old.
Offline Strawdawg
    • Vortex Buicks
« Reply #4 on: September 05, 2011 - 08:11:06 PM »
And, in that case, you can contact Mr. Q and see if he has an Auto-Grip handle for the '70 because it is the best solution :wavingflag:
Offline tman
« Reply #5 on: September 06, 2011 - 12:37:38 AM »
Thanks Q for the instruction.
« Reply #6 on: September 06, 2011 - 09:33:59 AM »
I installed a helicoil into the plastic knob on one shfiter button but it ripped out the helicoil , you can try to helicoil the button , I would use some JB weld behind the helicoil if you try that . Steve is correct it is keyed to the outer knob & they both thread down together but do not thread it on too far or the button will not depress far enough to clear the detents
 Steves [Quapman] shifter is by far the best option , it is all steel & you will not have any issues with it & it installs in seconds , I have put those shifters in a few cars now & my customers love them
