4cruzin's stupid question area
Author Topic: 4cruzin's stupid question area  (Read 9203 times)
Offline Robb
Re: 4cruzin's stupid question area
« Reply #45 on: May 30, 2005 - 12:41:07 PM »
Ok next question . . .today I went to install the hose connections for the heater core. . no problems, I tapped the holes to make sure the threads were in good condition and to remove any excess paint.
My own stupid question:
On your waterpump, are your fittings reversed ?    The tall one should be on the hole closest to the Radiator ??
70 Challenger SE  (440 SIX PACK / Keisler 5 speed, R/T SE replication)       68 Sport Satellite Convertible 383 Super Commando / 727  Survivor
2002 Trans AM WS6 convertible:  DD
1999 4Runner 4x4:  lifted-locked-armored  expedition vehicle
1990 Jeep XJ 4x4:  Front Dana 60, GM-14bolt rear, 3 link, 4link, 5.38 detroits, beadlocked 40's, stretched to 110" wb  Rock Crawler
Offline Robb
« Reply #46 on: May 30, 2005 - 12:47:34 PM »
Ok next question . . .today I went to install the hose connections for the heater core. . no problems, I tapped the holes to make sure the threads were in good condition and to remove any excess paint.   Installed the fittings and started looking at the hoses. One is smaller than the other but the outlet at the heater core. . . those pipes are the same size??  It doesn’t take a rocket scientist to figure the smaller hose isn’t gonna fit!  Is there a reducer or something that needs to be added??
The heater control valve has the same connections at the Firewall side, (two equal diameters)
but going to the block, that is there the diameter to the smaller hose changes size.
Offline 4Cruizn
  • HEMI FISH
« Reply #47 on: May 30, 2005 - 07:26:39 PM »
Actually Rob we ended up changing the fittings and now they're both the same size.   :beer:
Offline Robb
« Reply #48 on: June 01, 2005 - 08:57:40 PM »
If theyre the same size, then are you skipping the install of a valve control ?   :dontknow:
So then... youre going to have the heater on all the time ?
