Author Topic: Car running rough  (Read 847 times)
Offline 73 ralley
Car running rough
« on: September 05, 2011 - 08:02:03 PM »
Looking for some help from you all out there. My BB runns real rough when started so bad you cannot even get the rpms up. I did narrow it down after elimating distributor, coil, unilite ignition. When i unplug either of the field wires off the alternater it runs smooth again even if I unplug both of them it runs smooth, soon as I plug them back in it runs rough. I thought altenator so replaced with new but same thing. I did try an old regulator i had, with no difference.
Any thoughts?
Offline Strawdawg
    • Vortex Buicks
Re: Car running rough
« Reply #1 on: September 05, 2011 - 09:47:49 PM »
what is the voltage when the alternator is connected?
Offline 73 ralley
« Reply #2 on: September 05, 2011 - 11:58:54 PM »
Voltage with it hooked up is about 12.66 volts. it doesn't change hooked up or not I just can't get any rpm's from it when it is hooked up.
« Reply #3 on: September 06, 2011 - 12:07:55 AM »
I would have the Alt tested , sounds like it is bad , probably shorted & putting load on the alt causing the vibration
Offline 73 ralley
« Reply #4 on: September 06, 2011 - 09:19:40 AM »
it is a brand new alt but i guess you get good and bad inn them to. I will take it and get it tested to confirm.
Thanks, i'll keep trying.
« Reply #5 on: September 06, 2011 - 09:26:08 AM »
A friend installed a new Chrome Powermaster alt , it lasted approx 50 miles
Offline jimynick
« Reply #6 on: September 06, 2011 - 04:28:16 PM »
 :iagree:  You should show approx. 13.5-14.2 volts on a healthy alternator, new or not. Check the rotation when you get it off, the bearings may be grabbing, causing enough drag to affect the engine idle.  :2cents:
Offline 73 ralley
« Reply #7 on: September 06, 2011 - 09:13:24 PM »
I dropped the alternator off today, I'll let you know how it turns out.
