Diaphram Clutches feel ALOT different than three finger clutches. You will get that "Over center" feel ALOT more easily with the diaphram style than with the three finger. However, if your linkage is set up with the over center spring under the dash on the pedal assy, then there's part of your problem. You do not need the spring on the pedals with the diaphram style clutch.
