Author Topic: Haywire Wiring?  (Read 1207 times)
Offline Johnko2012
    • JohnKo Systems Unltd
Haywire Wiring?
« on: September 07, 2011 - 08:59:57 PM »
1973 barracuda, got it a couple of weeks ago, and all the electrical was working fine. Then one day:
     Flicking right turn signal makes signal spazz out, CD player (I don't think that is stock ;-}) turn off, and the dome light turns on.
     Left switch spazzes a bit too, but not so bad. And it doesn't affect any other part of the wiring...
   Any suggestions?  My mechanic buddy suggested it may be the floor dimmer switch... The signal stem seems to 'click" into place well...
    And by the way, what is it with the thrill I get from using that floor mounted dimmer? Does anyone else get off on that? Some kind of latent foot based control issues, I guess...
     JohnKo
JohnKo
Re: Haywire Wiring?
« Reply #1 on: September 08, 2011 - 11:01:21 AM »
Would that be haywiring ??
 anyway I would start with cleaning the bulkhead & column connectors & put some di - electric grease to keep the corrosion from happening again. next check grounds , if they are poor it can cause the electrical current to take a different path
Offline Johnko2012
Re: Haywire Wiring?
« Reply #2 on: September 08, 2011 - 04:04:32 PM »
Thanks for the tips, and thanks to whomever for moving my post to the right place --  i'm still figuring out the system here :-)
   Is the bulkhead the firewall?
JohnKo
Re: Haywire Wiring?
« Reply #3 on: September 08, 2011 - 04:09:00 PM »
Yes. The harness' on one side, the fuse box on the other.
Offline Johnko2012
Re: Haywire Wiring?
« Reply #4 on: September 08, 2011 - 04:54:55 PM »
Gotcha,
   Thanks folks!
      JohnKo
JohnKo
