Author Topic: New 440 carb problems please help  (Read 1415 times)
Offline Sonnythebull
« on: September 08, 2011 - 06:16:21 PM »
I just bought a newly done 1973 challenger restomod with a 440 bored 4.75 all new with an electronic ignition and holley carb. The car starts easy, cruises well and wide open throttle is perfect. Except when the engine gets fully warmed up it wont idle when I pull up to a stop light. If I start it and let it idle in the driveway it idles perfect. If I throw it in neutral while rolling along at speed it idles perfect. If I drive along and come to any stop it stumbles and stalls. Any suggestions? Thank you :wow: :rebel:
« Last Edit: September 08, 2011 - 07:05:47 PM by Sonnythebull »
Offline mopar12372
    • mopartech
Re: New 440 carb problems please help
« Reply #1 on: September 08, 2011 - 11:31:03 PM »
try   adjusting  the idle in gear. block the tires
RESTO PICTURES
« Reply #2 on: September 09, 2011 - 08:50:00 AM »
It will idle when in drive. It only stalls when you are coming  to a stop
Offline Oldschool
  • Member Since 9-05-06
« Reply #3 on: September 09, 2011 - 09:04:09 AM »
I had a BB Satellite that did the exact same thing. It turns out it wasn't anything to do with the carb. Torque converter was fried and pretty much locking the engine down. Replaced the torque converter and it ran like a top....    :rebel:
Ken  --  In Georgia
« Reply #4 on: September 09, 2011 - 04:02:06 PM »
could be a vacuum drop problem when you e on the brakes , you may have a leak in the brake line or booster or a problem with the carb when the vacuum is dropped to low , what carb do you have ?
« Reply #5 on: September 09, 2011 - 05:07:15 PM »
He has a Holley, but vacuum leak was my first thought.
You could try to spray some water around the base of your carb while it is idling. Notice if the RPM's change as you do this. Same for the intake gasket. My problem was under the carb.
Offline mopar12372
    • mopartech
« Reply #6 on: September 09, 2011 - 06:38:56 PM »
blown power valve ?
RESTO PICTURES
« Reply #7 on: September 09, 2011 - 06:46:23 PM »
or the PV is too high causing it to open when the vacuum is used for the brakes
« Reply #8 on: September 09, 2011 - 07:12:48 PM »
Disconnected the line from the carb to the evap can. Seems problem is solved. Thanks for all the suggestions
« Reply #9 on: September 09, 2011 - 08:09:46 PM »
Cool , not a place I would have thought of without the car in front of me
 Glad you got it solved  :2thumbs:
« Reply #10 on: September 09, 2011 - 11:21:08 PM »
Thanks
