Author Topic: Ballast resistor problem?  (Read 2152 times)
Offline 06Daytona
« on: September 09, 2011 - 09:46:39 AM »
The engine cranks over fine, stumbles as it tries to start, but when I let go of the ignition it stops. I have spark and fuel, new coil, new cap.
My thoughts are either ballast resistor, or points, one or the other since the engine started fine when I pulled it from the Charger
1972 Cuda 340 4 barrel 4 speed that looks like a 71
2006 Dodge Charger R/T Daytona
2005 Dodge Ram 2500 Diesel 4X4
2006 Chrysler PT Cruiser Convertible (Kidmobile)
1972 Dodge Charger 318 auto
1970 Challenger 440/727 auto
1973 Plymouth Duster 340/auto (Making it Panther Pink for the wife)
2006 Honda Civic Hybrid (It doesn't save gas, it just diverts it to the Cuda/Challenger)
In desperate need of more property for my growing Mopar family
Offline 72 cuda
Re: Ballast resistor problem?
« Reply #1 on: September 09, 2011 - 11:19:10 AM »
To my memory the ballast resister could be the culprit.
there are 2 kinds 2 prong and 4 prong.
Basically the 2 prong reduces voltage to the points to keep them from burning up so quickly.
The 4 prong has two functions it allow more voltage during the start position, and reduces it when in the run position.
Chryco or half the guys on this list can tell you the voltages.
Either way it should be easy to check with a test light.
Mark
 :rebel:
Offline 06Daytona
« Reply #2 on: September 09, 2011 - 12:12:29 PM »
It turns out that the ballast resistor was the problem. I had a spare kicking around the garage so I hooked it up and the engine started without a problem.
