Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Transmission and Drivetrain
(Moderator:
Chryco Psycho
4 speed shifting problem
« previous
next »
Print
Pages: [
1
Author
Topic: 4 speed shifting problem (Read 753 times)
72challcan
Jr. Member
on:
September 09, 2011 - 05:18:19 PM »
Just converted a 70 chall 340 from auto to a 4 speed (833)and am having problems shifting into 2nd gear. It is a Hurst Shifter with the competition plus. I can get it to shift into second gear when shifting from 3rd to second with a little work but it will not go into second starting from first gear. Any suggestions? Also is there somewhere on line that I can get a exploded diagram of both the linkage and the internal gears to see if the transmission was put together correctly Thanks
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: 4 speed shifting problem
Reply #1 on:
September 09, 2011 - 06:23:09 PM »
I wish I was still in the area I would fix it , actually if you have enough work at some point I woul dbe happy to come back & help . The service manual cover things pretty well .
I assume it will never slide into 2nd ? but it does smoothly from 3rd ?
Does it slide in smoothly from neutral ?
Is this sitting still ? engine running or not , while driving it ?
If the syncro was hanging up it should be the same from 1st or 3rd
Neil
Logged
Cooter
Sr. Member
There goes the lone Challenger............
Reply #2 on:
September 09, 2011 - 06:54:16 PM »
When you say "Put together correctly", what are you referring to? Has someone done a home rebuilt, hack job on it?
Sounds like a shift rod is out of adjustment, or the shifter positive stop is adjusted in correctly...
Last Edit: September 09, 2011 - 06:57:10 PM by Cooter
Logged
1969 dodge Charger "General Lee" [___|______I______|___]
1968 Dodge Dart 2dr sedan 505" Stroker (O]=0==========0=[O)
1970 Challenger R/T Clone "Kowalski Special" (OO) [___________] (OO)
72challcan
Jr. Member
Reply #3 on:
September 09, 2011 - 07:45:37 PM »
with car sitting it will not go into 2nd. while driving the car it will go into second gear if ynou shift from from 3rd(not easy) but will shift. I purchased the transmission on ebay a complete rebuild and other than this issue seems reasonably tight . Neil I am near the end of this basically frame off so I do not have enough work to bring you here but am experiencing a few wiring issues and this transmission problem. Frank
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #4 on:
September 09, 2011 - 08:34:13 PM »
Figured I would offer , not sure how far along you were !!
I am living Panama now , drop by for a visit Frank
check out the website too
Neil
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
