Author Topic: rochester 4 barel vs thermodquad 4 barrel  (Read 1117 times)
Offline WVUFELLA
  • (OO/---------\OO) closest i could for a 72
« on: September 11, 2011 - 08:06:08 PM »
hey guys i know this is a lil off kilter here buttt...... i have a 78 pire wagon with a 360 all stock ... i am lookin to put a factory 4 barrel 360 intake manifold on the truck was lookin to but a carb thru gauranteed carberators.com   .. th eoptions are a thermoquad and a rochester.. both 4 barrel.... I am lookin for the most reliable  carb here  .. this is by no means a performance beast... i just want somethin dependable to use for a work truck.... whats yalls take?????
Re: rochester 4 barel vs thermodquad 4 barrel
« Reply #1 on: September 11, 2011 - 08:14:50 PM »
in the mid 80s after cater went broke Mopar ran Q jet carbs for 2-3 years before going to EFI
 Parts for tuning are hard to get for either carb , , I am sure either would work OK
« Reply #2 on: September 11, 2011 - 08:17:03 PM »
There's nothing inherently wrong with either, they just need to be built and dialed in properly.  Sounds like you are keying on spread boar carbs probably because of the intake design, most any carb can be adapted. I have an Edelbrock Performer that has both bolt patterns that would bolt straight on.
Offline Cooter
    • christinecarclub.com
« Reply #3 on: September 11, 2011 - 08:23:01 PM »
I have never had any luck with either being a "Reliable" carb. The TQ carb's have that ever popular, POS Plastic (or some variation thereof) center body that likes to cause massive fuel leaks and NO starts, while the Q-Jet carb's tend to be worse than a Holley to tune and get "right/Reliable"...
Edelbrock 600 with an adapter, and be done with it...
Offline Challenger6pak
« Reply #4 on: September 11, 2011 - 11:23:08 PM »
My old truck came with the Q-jet and it still has it.  It sat for 6 months and I fired it up and drove it with no problem.  I have never had problems with either the T-Q or the Q-jet.  Since the Q-jet is being made again it may be easier to get parts.  I think the T-Q is  a little easier to rebuild.  Set up properly either carb should give better performance and maybe better mileage than the 600 Eddy.
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #5 on: September 12, 2011 - 12:28:51 AM »
I put a Quadrajet from an oldsmobile on my 318 powered 5th Ave and it work pretty well.  I like the smaller primaries so I went with that instead of a sqarebore Holley.
Offline WVUFELLA
« Reply #6 on: September 12, 2011 - 02:33:26 PM »
hey guys i know i am prolly wasting my time but is there much a diff bewteen the 2 barrel and 4 barrel as far as mileage??? i have the argument of ..... well the primaries on a 4 barrel are smaller and the two two barrel primaries and since your using primaries most fo the time  then it uses less gas......i am not expecting awesome mileage but with a heavy truck liek this and full time 4x4 .... every 1/1000000 of a mile/ gallon counts
« Reply #7 on: September 12, 2011 - 04:48:16 PM »
My personal experience has been that the 4 bbl. will get the better gas mileage.  That is as long as you keep your foot out of it and do not open the rear barrels.  That is the concept and purpose behind the spread bore carb.  You cruise on the small primarys and have the added CFM and power potential when you open up the rear barrels.
