How to build the strongest 8 3/4 rear end
Author Topic: How to build the strongest 8 3/4 rear end  (Read 5619 times)
« on: September 12, 2011 - 10:14:13 AM »
What parts would you recommend in " putting your best foot forward" if you are building a 8 3/4 for strength? ( Street car)
 What axels? spline count?
Who's/what carrier?
Who's/what yoke?
Truetrac?
Detroit locker?
stock limited slip?
I know some will say just get a Dana 60, but I'm curious about beefing up a 8 3/4.
Re: How to build the strongest 8 3/4 rear end
« Reply #1 on: September 12, 2011 - 10:24:22 AM »
I went down this path , , bought Strange race axles 35 spline , spool , braced the back of the housing built a 742 center section welded cap supports into the housing , used the race U bolt yolk , took my car to the track launched the car at the bottom end of the power band around 3000 rpm & chewed 37 of 43 teeth off the ring gear on the first pass .
 In my duster I did the same thing , MW axles , stock sure grip , ladderbars for traction & ate a sure grip every 2 seasons
 Save you $$ & Build a Dana
« Last Edit: September 12, 2011 - 12:33:16 PM by Chryco Psycho »
« Reply #2 on: September 12, 2011 - 12:31:29 PM »
What about strickly street duty. No slicks?
I'm just thinking about my new engine making more power than the stock drivetrain can handle? :dunno:
« Reply #3 on: September 12, 2011 - 12:39:53 PM »
I will tell you this it will cost more to buy all the good parts for the 8 3/4 , buy the time you get a premium carrier , gears & I would use the Eaton / Torson diff for a sure grip , buy 35 spline axles you can build a Dana for less , you will add 50 lbs of unsprung weight but the car will hook harder with the weight on the tires . Are you planning to swap gear ratios?  That would be the only reason to use the 8 3/4 that I can see . A dana will/ should come with 35 spline axles stock & a clutch type sure grip & race yolk if you start with a Ford unit , it can certainly be ordered that way .
Offline Cooter
    • christinecarclub.com
« Reply #4 on: September 12, 2011 - 01:09:45 PM »
Brad, I've found that my cars see far worse driving/abuse on the street pulling holeshots in front of friends, bangin' gears, etc.
Even IF you get an 8 3/4 to live for a short while, that new stroker making 500-600 HP and torque will eventually beat to death ESPECIALLY if you run a stick, but a properly done 727 with stall and shift kit will give it hell. Street duty is ok if you have another limiting factor like racing fuel and weak engine/trans..You know as well as I that you will beat on that thing sooner or later. Better to have a Dana 60 when that time comes IMO.....
Offline Cuda54
« Reply #5 on: September 12, 2011 - 09:47:15 PM »
Where can you find a Dana 60 the right width of a b body rear end? It can be out of any thing because it will have a 4 link to install it.
« Reply #6 on: September 12, 2011 - 10:43:43 PM »
the ford truck diffs can be narrowed or you can have them built to spec
« Reply #7 on: September 13, 2011 - 06:01:42 AM »
I'll keep an eye out for one. What years of Ford truck are they in again? 150?  250? 350?
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #8 on: September 13, 2011 - 06:38:50 AM »
Looks like $1895 will get you a brand new one just the way you want it
http://www.strangeengineering.net/catalog/072.html
Go Fast & Have Fun...
« Reply #9 on: September 13, 2011 - 10:52:09 AM »
Doctor Diff in Poulsen MT is a little cheaper I belive & yeah you could have them built to the B body width for extra tire clearance with the offset springs .
Mid 70s - 80s ford 250 maybe 350 trucks , the webbing on the center carrier will have the 60 or 70 cast into them , stay away from the 70 , usually you can find them with a sure grip & the gear ratio you want
« Reply #10 on: September 13, 2011 - 04:14:54 PM »
Just looking on here...
http://www.car-part.com/cgi-bin/search.cgi
I searched for a 1980 250 Ford pickup, options were a "spicer 60" is that the same thing as a Dana 60 Spicer/Dana are one in the same are they not?
« Reply #11 on: September 13, 2011 - 04:18:52 PM »
yes
« Reply #12 on: September 13, 2011 - 04:42:19 PM »
yes
I just phoned around the local yards around here with no luck. Not a big pick up truck area around here. I do know were and old Dodge 67-69 truck is sitting with a floater Dana 60 in it. Would that work? Only thing is he thinks the truck is gold?  It's been sitting for years all rusty etc.... came from out west has a 383 stock in it. :blah: :blah:
Where do you get the housing ends, axels etc....?
« Last Edit: September 13, 2011 - 05:16:58 PM by brads70 »
Offline Katfish
  • 70 Challenger
« Reply #13 on: September 13, 2011 - 08:06:37 PM »
Check ebay, looks like this guy is converting the Ford rear end and they even include disc brakes.
http://cgi.ebay.com/ebaymotors/Dana-60-B-Body-Mopar-/130574301819?pt=Motors_Car_Truck_Parts_Accessories&hash=item1e66d5ba7b
« Reply #14 on: September 13, 2011 - 08:11:52 PM »
Bears can supply you with axles , housing ends & the ford tapered roller brg . All strange stuff
you might get it cheaper in the US now .
 most of the diffs are floaters , I have seen some no floater 60s in fords
 we did a thread on modifing Danas earlier this year in theis section if you do a search for ti you may find it
