Author Topic: My car overheats when it idles to long having another issue.  (Read 3339 times)
Offline Matt70
Re: My car overheats when it idles to long having another issue.
« Reply #15 on: September 13, 2011 - 05:55:07 PM »
Why do you say the radiator needs flushed "badly" if your coolant looks like mud start there.
Here is a pic of the vacuum advance the arrow is pointing at it. Disconnect the vacuum line going to it and take it for a drive to see if it helps with the missing problem like Chryco said. (I have a small block so my distributor is at the back of the engine, yours will be on the front)
People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf.
George Orwell
Offline torqueaddict
« Reply #16 on: September 13, 2011 - 06:09:19 PM »
Amy suggestions on a fan shroud like where I should get one and how much I should pay? And I know my radiator needs to be flushed because the jackass that dropped my motor put water instead of anti freeze. So I have rust water cooling my car(good mechanics in my area are not easy to come by) I rarelyy drive the car so flushing it has been kinda on the back burner. I'm thinking because it only overheard when idleing that the fan shroud and flush might solve that issue. The backfiring is a lil more complicated tho.
1972 Challenger  (O O [======R/T=] O O) 1970 clone
« Reply #17 on: September 13, 2011 - 07:19:27 PM »
I'm more worried that you radiator isn't clogged.
You can get a 26" shroud for your radiator, but if you have a 22"... Good luck.
« Reply #18 on: September 13, 2011 - 08:05:12 PM »
What does the rad cap look like , if it is old & the spring is weak it will not pressurize , A/F will resist boiling better too
« Reply #19 on: September 13, 2011 - 08:13:45 PM »
Any suggestions on where I can get a shroud for a decent price? I will do a flush on friday. Hopefully yhat will solve my issue there.
Offline Matt70
« Reply #20 on: September 13, 2011 - 08:24:02 PM »
Contact Dave (he's a member here) at Roseville, they are great to deal with and give C-C.com members discounts
George Orwell
« Reply #21 on: September 13, 2011 - 08:36:53 PM »
What's his info so I can hit him up about that. Is that Roseville ca or some other state?
Offline Matt70
« Reply #22 on: September 13, 2011 - 09:23:30 PM »
Roseville MI, the company is a sponsor on this site. His screen name is mopardave or just go to Rosevillemoparts.com
Roseville has a thread in the vendors section of the forum you can ask him questions there.
George Orwell
