Author Topic: wiring question.  (Read 1215 times)
Offline lime73
wiring question.
« on: September 13, 2011 - 06:10:47 PM »
what under the hood has 12v with key in on position and also while cranking?  reason i ask is i am wiring MSD box and cleaning up unnecessary wiring and need a constant 12v signal even while cranking for box.   Thanks in advance for your help.
Offline mopar12372
    • mopartech
Re: wiring question.
« Reply #1 on: September 13, 2011 - 07:04:46 PM »
the msd is very finiky. make sure it has its own circuit . if you are not useing the ac that circuit is perfect . some times there are fuse openings with only the hot on one side check your fuse box for blank spaces and check the jot run with key switch , do it with a volt meter to make sure your getting the correct voltage in the circuit your working with.
RESTO PICTURES
« Reply #2 on: September 13, 2011 - 08:14:03 PM »
You will have a dark blue run 12v & a brown wire 12v cranking at the ballast resister , connect them together to the red trigger wire for the MSD
Offline lime73
« Reply #3 on: September 15, 2011 - 05:13:29 PM »
Thanks Chryco worked like a charm...   LIGHT EM UP BOYS !!!!!!!!!!
« Reply #4 on: September 15, 2011 - 06:38:55 PM »
 :2thumbs:
Offline Kevin71
« Reply #5 on: September 24, 2011 - 04:54:34 PM »
Chryco
Are you talking about wiring all three together.  I take it this will illminate the balast resistor.  I have 2 wires coming in and 2 wires going out of my ballast resistor.  What do I do with the other 2 wires?
« Reply #6 on: September 24, 2011 - 09:27:37 PM »
Chryco
Yes it does. The MSD does not require the resistor.
« Reply #7 on: September 24, 2011 - 10:54:38 PM »
Exactly , wire the Blue , Brown & red MSD trigger wire together , the other two wire out of the Ballast power the ECU which is replaced by the MSD & the coil feed which is also eliminated as the coil is fired by the MSD , so the ballast goes bye bye too
