Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Engine & Go Fast Goodies
(Moderator:
Chryco Psycho
360 with 750 cfm carb stumbles under light throttle pedal pressure
« previous
next »
Print
Pages: [
1
Author
Topic: 360 with 750 cfm carb stumbles under light throttle pedal pressure (Read 1207 times)
EMCD
Full Member
on:
September 17, 2011 - 01:07:16 PM »
If I mash it to the floor it flies off the line. If I light depress the pedal, it stalls. Would my primaries be the issue?
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: 360 with 750 cfm carb stumbles under light throttle pedal pressure
Reply #1 on:
September 17, 2011 - 02:10:18 PM »
Well yes & no
it has to do with Accelerator pump & float level
So may be we should start with What make of Carb
Logged
EMCD
Full Member
Reply #2 on:
September 17, 2011 - 02:14:40 PM »
Edelbrock model 1407, 750 cfm
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #3 on:
September 17, 2011 - 02:24:59 PM »
Figured they all do that
you can install a bigger squirter , but Eddy forces you to by a pack of 3 to get it , pull the top off the carb to change the squirter ,& check / raise the float level slightly , it should be 7 /16 raise it 3/8
Logged
EMCD
Full Member
Reply #4 on:
September 17, 2011 - 03:16:16 PM »
Cool. Thanks. Where can I pick up a set of squirters?
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #5 on:
September 17, 2011 - 03:33:20 PM »
Local performance shop , Summit , Jegs
Logged
UKcuda
Full Member
Tell them I'm on my way
Reply #6 on:
September 22, 2011 - 09:16:19 AM »
Alternatively it could be the rod springs are allowing the rods to stay down too long as it comes off idle.
I had a 750 AFB (basically the same as your Edelbrock) that was doing exactly what you describe. I went one stage heavier on the rod springs and it cured it.
If the springs are too weak then increasing the pump shot may appear to cure the problem but actually you will only be masking the real problem so it may be worth trying different springs first.
Logged
'72 'cuda
Chryco Psycho
Administrator
C-C.com Guru
Reply #7 on:
September 22, 2011 - 10:25:49 AM »
good to know , always learning something
Logged
UKcuda
Full Member
Reply #8 on:
September 22, 2011 - 12:29:08 PM »
Quote from: Chryco Psycho on September 22, 2011 - 10:25:49 AM
It's worth a try, and while I'm thinking about it another thing to check on these is slack in the squirt pump linkage. If there's slack the squirt lever doesn't get moving enough when you crack the throttle only a little way. It shouldn't happen unless someone has been playing with the carb, but at least it's easy to check and easy to fix.
Logged
'72 'cuda
EMCD
Full Member
Reply #9 on:
September 22, 2011 - 01:49:16 PM »
Cool man. I'll check it out.
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
