you can still get the brg , retainer rings ,& outer seals in a kit ,no I don't have the part # .
the problem is first you have to cut the retainer ring to remove it & you will damage the retainer plates & adjuster pressing the brg off the axle so you need to cut the brag off as well to save the retainer plates as they are no longer available , then you can press on new brgs & retainers , usually the retainers need to be heated to install them
