Hey Cuda Hunter, any chance you'd be able to help me out some more?
I had to cut off the RH motor mount bracket as it was too buckled to bend back into position.
I have everything clean and ready to weld, but it just doesn't seem to be fitting right.
I made a simple jig to keep the distance between the holes in the motor mounts correct, to simplify matters,
but when I set it up so the top point of the mount matches the 3 and 9/16" measurement it seems really high.
The parts where I've cut don't match back up at all, when you'd think they should...
So, fearing a more bent K member than I had anticipated, I'd love some more measurements if possible.
Basically as many as you can, I've made some reference images of what I think would help,
but please feel free to add any that you think would make the job of sorting out this damn K member easier.
A photo of your K member from the same angle as the photo above would be great.
Are the two holes level on yours?
A series of square-on photos would be great: top, side, front and rear etc.
I'll hook you up with free photochops for life if you can help me out!
