Author Topic: oil leak  (Read 1336 times)
Offline coupman35
  • It going to be FUN
oil leak
« on: September 18, 2011 - 09:26:51 PM »
When for a long ride this weeken and when i got home i had oil all offer the engine fire walk.Look like it came out of the dip stike .Is it because to much presher is that what they call blow back.How can i fix this
1941 Dodge truck 340cu
1935 ford 3window coupe 327cu
1965 Acadian Beaumont Convertible 283cu
1973 Challenger 318cu
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
Re: oil leak
« Reply #1 on: September 18, 2011 - 09:30:02 PM »
I would start with the pcv valve and see if its good,if thats alright run a compression check
72rtchallenger
what happens in the garage
stays in the garage
Offline coupman35
Re: oil leak
« Reply #2 on: September 18, 2011 - 10:13:46 PM »
the pvc valve was good but it only conected to my air breather and not much vacume from there .Maybe the hose is not big enough.
  • 72 to 70 clone
    • cardomain
Re: oil leak
« Reply #3 on: September 19, 2011 - 12:08:16 PM »
I believe the pcv valve should route to the base of the carb,,but if this is a new problem I would still run a compression check
72rtchallenger
stays in the garage
Offline 72cudamaan
Re: oil leak
« Reply #4 on: September 19, 2011 - 08:34:32 PM »
Sure it's not just a bad o.p switch? I've seen it happen alot.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline coupman35
Re: oil leak
« Reply #5 on: September 19, 2011 - 09:00:57 PM »
Well did  a compretion test 7 of the m are at 120 plus and one at 115 so that all good .Was looking at my pcv valve i only got it going under my air breather.Now i got it going to the intake will have to try that out.
Cudaman what is the o.p. switch.Buy the way i only drive the car for about 400 mile sint i restored it so this is some bug that are coming out.
Offline 72cudamaan
Re: oil leak
« Reply #6 on: September 19, 2011 - 10:14:10 PM »
Oil pressure sending unit. It often fails and starts to spray oil right out of the
electrical connection.
Offline coupman35
Re: oil leak
« Reply #7 on: September 19, 2011 - 10:29:07 PM »
Thanks will check that out tomorrow.
  • 72 to 70 clone
    • cardomain
Re: oil leak
« Reply #8 on: September 20, 2011 - 04:01:20 PM »
good call very possible
72rtchallenger
stays in the garage
Offline coupman35
Re: oil leak
« Reply #9 on: September 20, 2011 - 08:46:39 PM »
Ok i check it it in the back of the motor and looks clean.The oil look more like it coming out of the dipstick in the front.
Offline jimynick
Re: oil leak
« Reply #10 on: September 20, 2011 - 09:07:12 PM »
At the risk of asking the obvious, do you have breathers on the valve covers? That's a lot of blow-by to puke oil all over. You may want to do a leak down test as well.  :2cents:
Offline coupman35
Re: oil leak
« Reply #11 on: September 25, 2011 - 07:40:16 PM »
Well finaly got the car out for a test drive .This time i but and paper towel around the dip stike to see if the oil came out from there .Wellit did a bit dont look like much.Am going to conect the pcv valve right on the valve cove right noe it going tru a small valve cover air breather hope that helps .Will up date
