I am also concerned about the oil pressure on my freshly rebuilt eng.(383)
I finally got it running and did the break in on the cam . Im worried because my mechanical gauge(after market) is only showing 22psi at 1000rpm(which seems a little fast for an idle) . The manual states it should be 20psi@500rpm, but at that rpm, my gauge is only showing around 8psiand my "dummy"light is flickering. I also took the line off of my gauge and allowed some oil to flow out, because it had some air bubbles in it. ( A mopar friend suggested that I could have an issue with my oil pick-up possibly being too close to the bottom of the pan. The funny thing is, is there are ticking noises or any other noises that would go along with low oil pressure.
WHAT I HAVE:
Stock rebuild, new hi po oil pump, new oil pan(from 440 source ,not an exact match to my old 402 pan. it did not have the same slope on the shallow end of the pan, which also caused a clearance problem with the steering control arm), oil pump pick up(440 source which I had to alter (shortened the length by cutting off a little of the threaded end) because pick up was hitting on bottom of pan and keeping the pan from seating on the block) , windage tray with 2 gaskets, Comp Cams break-in oil. For my oil pressure guage and dummy light, I have a"T" fitting coming off of one of the oil ports on the rear of the engine.
Could the gauge be bad?
Could the "T" fitting cause a problem?
Could the port be clogged (should I try the other port)?
What should the correct distance be between the pan and the bottom of the pick-up ?(if it is touching the bottom, could this be my problem)?
One other thing, the engine had the same problem(low oil pressure/dummy light flickering at idle)before I had it rebuilt. I am wondering if maybe the guy who rebuilt it, hot tanked the engine but didn't run brushes through the oil gallies. He hasn't had the courtesy to return my calls.
thanks
