Author Topic: 73 Barracuda Tail light Wiring Diagram & Help Needed  (Read 2385 times)
Offline Road_Runner
« on: September 20, 2011 - 12:05:00 PM »
The wife was following me home the other day and told me the only light working correctly was the outer passenger side one, she said the driver side brake light wasn't working.  So when we got home I had her run through the lights while I stood behind the car and it turns out the inner two lights aren't lighting up at all, and the driver side light goes out completely when the brakes are on.  The original owner towed a boat with the car so there are lots of splices in the harness in the trunk.  Does anyone have a wiring diagram they could share showing the trunk lights? and I'm a total novice trouble-shooting electrical problems so any advice there would be greatly appreciated!
Thanks, Jim
1970 383 Roadrunner Tor Red
1973 318 Barracuda Mist Green
Offline Slotts
Re: 73 Barracuda Tail light Wiring Diagram & Help Needed
« Reply #1 on: September 20, 2011 - 01:36:03 PM »
Hey Jim,
This should do it for you.
http://www.mymopar.com/downloads/1973/73BarracudaB.JPG
Slotts
« Reply #2 on: September 20, 2011 - 02:09:11 PM »
if one light goes out when the brakes are on you have a bad ground on that light & it is using the park light circuit for ground
Offline ShelbyDogg
« Reply #3 on: September 20, 2011 - 03:24:31 PM »
Listen to what Chryco just said, bad ground. I always solder a long black wire to each tail lamp socket then ground it theeo the body somewhere with star washers and a sheetmetal screw. The weatherstripping usually isolates the tail lights from the body. Verify the bad ground with a jumper wire from the socket to the body metal.
Offline Road_Runner
« Reply #4 on: September 20, 2011 - 09:36:33 PM »
Awesome guys, thanks for the help.  This gives me some place to start and especially thanks for the diagram Slotts!
Later, Jim
