Author Topic: Console Paint  (Read 662 times)
Offline 70challengersix
Console Paint
« on: September 20, 2011 - 08:44:38 PM »
I need a recommendation on what kind of paint to use on a black console used in my challenger.  I have a nice "green" colored door to replace the broken black one.  The rest of the console is in very good condition.
Tips like what kind of paint to use, and surface prep would be appreciated.
Thanks in advance
Re: Console Paint
« Reply #1 on: September 21, 2011 - 08:55:47 AM »
Go buy some SEM Adhesion Promotor and some SEM Landau Black spray paint.  I recently sprayed my A-pillars, kick panels and lower dash trim pieces with those products and they turned out great.  The Landau Black is a very close match to the original gloss of the plastic.
Here's a picture of what the kick panels looked like before being sprayed.
I washed them 4 times before spraying the Adhesion Promotor.  Once with soap/water....once with Simple Green....once with mineral spirits and finally with a wax/grease remover.  I sprayed the Adhesion Promotor per the dirrections on the can.  Follow the dirrections exactly.  After the final coat of the Promotor and after waiting 20 minutes, I applied a few mist coats of the Landau Black.  If you just mist the paint on, once it dries, you won't be able to tell that it's paint.  Get it on too thick and it will look painted.
Here's the finished product.
Re: Console Paint
« Reply #2 on: September 21, 2011 - 10:12:42 AM »
That looks fantastic.  I will follow your suggestions
Thanks Again!!!
Offline Blue Meanie
Re: Console Paint
« Reply #3 on: September 23, 2011 - 01:33:57 PM »
It would seem that there are any number of good black pieces floating around. Try trading for one. Someone with a green interior is probably just praying for a reproduction or good condition replacement like yours.
