Author Topic: undercoating help  (Read 624 times)
Offline chuck
undercoating help
« on: September 21, 2011 - 09:18:02 PM »
 :clueless: i need some ideas  on undercoating on my 74 cuda just recieved all my  sheet metal (AMD) from stefan thanks this guy is great but back to the question what do i use  3m shutz ,lizard skin powdercoat any ideas what would be the best any info and pics would be great  :feedback:
Re: undercoating help
« Reply #1 on: September 21, 2011 - 09:58:15 PM »
http://www.restorick.com/proddetail.asp?prod=Undercoat
Have you ever sprayed undercoating before?
If not, practice on a dummy panel so you get the right look like the factory did.
Distance, PSI, CFM and travel path are things to adjust to get the right stand up look.
« Reply #2 on: September 21, 2011 - 10:10:30 PM »
Mine actually was sprayed right over the Shock hole mount area. So when it comes to this stuff, it was a variable on the actual spray pattern from the factory.
