Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Engine & Go Fast Goodies
(Moderator:
Chryco Psycho
Adjustable rockers (273)
« previous
next »
Print
Pages: [
1
Author
Topic: Adjustable rockers (273) (Read 947 times)
RCCDrew
Sr. Member
on:
September 22, 2011 - 10:12:50 PM »
Bought some of the 273 adjustable rockers for the 340. Also bought the TA 340 style pushrods. I have a .484" lift hydraulic purple shaft in the engine. Now it seems like a few of the rockers are just barely touching the valvesprings when the valve is fully closed. They are so close that I can clear the rocker by rotating the spring (coil in a different position). Any ideas?
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: Adjustable rockers (273)
Reply #1 on:
September 23, 2011 - 10:06:54 PM »
the spring may be a larger diameter from the stock spring , you can shim up the rocker shafts , not the best way or just grind a bit of clearance under the rocker arm , do not leave any sharp ridges where you grind though , make it very smooth
Logged
RCCDrew
Sr. Member
Reply #2 on:
September 25, 2011 - 05:07:00 AM »
Yeah, the spring diameter is actually a little larger than the retainer. Worked on it a little. Seems to do fine.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #3 on:
September 27, 2011 - 12:15:45 AM »
Cool
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
