Author Topic: Temp Help ...  (Read 2721 times)
Offline 4x4HEMIrig
  • U. S. Navy: Interior Communications Electrician
Temp Help ...
« on: September 24, 2011 - 11:02:49 PM »
 :o ??? :-[ :-\ :dunno: :clueless: :sadwavey: :banghead: :1zhelp: :working: :faint:
Where does the temp sensor go?
-Aaron-
Bozeman, MT, USA (and wherever the Navy takes me)
2011 Jeep Wrangler Unlimited Rubicon, Rigid industries off road lights, Rough Country 4" suspension lift, CB radio... still working on it.
Fellow Service Members and Veterans, join me on www.togetherweserved.com, JK owners at www.jkowners.com, and Hemi Truck owners (and former owners) on www.hemitruckclub.com.
Former wheels: 1972 Dodge Challenger 340 Rallye, 2003 Hemi Ram 1500, 2006 Dodge Charger R/T.
Future projects in the garage: Streetable .030 over 383, 1977 Chevy Custom 20 SC/LB.
Re: Temp Help ...
« Reply #1 on: September 24, 2011 - 11:06:37 PM »
small hole in the water pump in an RB/B
Re: Temp Help ...
« Reply #2 on: September 24, 2011 - 11:08:48 PM »
Water cross over port at the front of the small block intake , it is a 1/8 pipe thread hole for the factory sender
Offline 4x4HEMIrig
-Aaron-
Re: Temp Help ...
« Reply #4 on: September 25, 2011 - 06:10:25 PM »
Is it too long or something? They both look to be 1/8 NPT? Just different ends for wiring?
Re: Temp Help ...
« Reply #5 on: September 25, 2011 - 06:59:41 PM »
if it is 1/8 " pipe thread that should be correct , unless it was mispackaged , the top one has the end that the factory used
Offline 4x4HEMIrig
Re: Temp Help ...
« Reply #6 on: September 25, 2011 - 07:19:08 PM »
The one O'Reilley's gave me is just too small.
The rusty part on the left is a packing nut. The sensor in the car now does not have any threads.
-Aaron-
Re: Temp Help ...
« Reply #7 on: September 25, 2011 - 07:33:44 PM »
That looks to be a mechanical temp gauge. If it's shot you will need to replace the entire gauge. It's not a factory part.
Offline 4x4HEMIrig
Re: Temp Help ...
« Reply #8 on: September 25, 2011 - 08:11:26 PM »
This is what it's attached to. I do plan on getting rid of this setup and returning to the stock gauges, once Classic Industries is up to speed on their parts.
-Aaron-
Offline 4x4HEMIrig
Re: Temp Help ...
« Reply #9 on: September 25, 2011 - 08:11:53 PM »
-Aaron-
Re: Temp Help ...
« Reply #10 on: September 25, 2011 - 08:15:59 PM »
Ya once the capiliary ( sp?) tubing gets a leak it's done. Maybe look for the stock plug in your wiring harness that attaches to the  temp sender that bhas the threaded top? (untill your new gauge gets to you?)
« Last Edit: September 25, 2011 - 08:21:34 PM by brads70 »
Offline 4x4HEMIrig
Re: Temp Help ...
« Reply #11 on: September 25, 2011 - 10:52:01 PM »
In the pic, the needle is pegged out. While the motor is running, it stays the same.
Shouldn't it be the other way around?
My mechanic said it should be around 230/240.
-Aaron-
Offline Strawdawg
    • Vortex Buicks
Re: Temp Help ...
« Reply #12 on: September 25, 2011 - 11:16:53 PM »
When the engine is off and cold, the needle should be sitting on 130, or whatever is the lowest possible reading.
When running and warmed up, it should rise to around 180-200, depending upon ambient conditions....
Offline 4x4HEMIrig
Re: Temp Help ...
« Reply #13 on: September 25, 2011 - 11:32:26 PM »
It was about 9pm when I took the pic, and the car has been sitting in the garage since about 4pm. When I pulled the temp sensor out, the coolant was warm, but not hot.
-Aaron-
Offline Strawdawg
    • Vortex Buicks
Re: Temp Help ...
« Reply #14 on: September 25, 2011 - 11:54:31 PM »
the gauge should always reflect the coolant temp...if it can read that low...or it will start to move the needle when the coolant rises above the minimum that the gauge reads
It may be the gauge itself that is fried and not the capillary sender....either way, you need a new gauge and sender, or install the factory sender and factory gauge
