Author Topic: 5 Speed Transmission Conversion  (Read 9495 times)
Offline cudaClive
« on: September 26, 2011 - 03:36:31 PM »
I'm looking for anyone that has upgraded their automatic transmissions to a manual 5 speed. My auto trans has decided to quit on me last Friday. Has anyone done this kind of swap? I'm thinking of getting one of Keisler's 5 spd trans. Any know how well they really work? And will the shifter fit into my auto console location.
Any help would be appreciated.
Offline mopardave
  • Sponsor
    • rosevillemoparts
Re: 5 Speed Transmission Conversion
« Reply #1 on: September 26, 2011 - 03:54:49 PM »
the kits are pretty good to use from keisler, simple to install, I have done 2 and nothing real major to deal with. you shift will be in the original location, the trans you get in the kit will be for that application. only thing is hydraulic clutch or manual clutch.
with the hydraulic, bleeding the bearing is a PITA..
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline cudaClive
« Reply #2 on: September 26, 2011 - 04:17:23 PM »
Thanks Dave. Did you get the 500 or 600 version? And what price did you pay? I haven't sent for a quote yet.
« Reply #3 on: September 26, 2011 - 08:23:55 PM »
I have nothing but issues dealing with Keisler & their products
 theree are better companies , Classic / Tony Edler does the same conversion kits & is a member here .
Offline D70challenger
« Reply #4 on: September 27, 2011 - 01:43:27 AM »
This thread intrigues me. Share the info!
1970 Dodge Challenger
2005 Ford Mustang
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #5 on: September 27, 2011 - 09:37:44 AM »
both set ups we did were the tko-600, Model Number TRM-E5008A  both went behind 472 hemis, one hydraulic clutch the other standard. paid 4k drive shaft to flywheel
« Last Edit: September 28, 2011 - 10:46:26 AM by mopardave »
Mopar Dave
73 F8 Challenger
1990 XJ - sold
Offline ragtopdodge
« Reply #6 on: September 27, 2011 - 10:32:30 AM »
If you're patient, I'd wait for either the new Passon 5-speed, or Keisler's RS units.  I hear powershifting a Tremec from 2nd to 3rd has issues.
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
Offline GoodysGotaCuda
« Reply #7 on: September 27, 2011 - 02:04:15 PM »
both set ups we did were the tko-600, both went behind 472 hemis, one hydraulic clutch the other standard. paid 4k drive shaft to flywheel
That a automatic to 6-speed or 4-speed to 6-speed price?
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #8 on: September 28, 2011 - 10:45:37 AM »
auto to maunual
Mopar Dave
73 F8 Challenger
1990 XJ - sold
Offline JeffAARy
  • Orange Mopars Drive Me Wild
« Reply #9 on: September 29, 2011 - 01:15:20 AM »
I did the 727-to-Keisler manual conversion 2.5 years ago.  I had clearance problems with the tunnel, and I even used an original 4-speed hump instead of a repop.  If you do some searching on the web there seems to be tunnel clearance issues with a small percentage of E-bodies, mostly AAR Cudas.  Not really sure why, or if the AAR thing is a coincedence.  It could just be that so many cars have replacement floors (and other parts), which can have a lot of varaince in installation.
Once installed the transmission is great.  When I bought my car it was almost undrivable.  The engine was screaming at 50 mph, and I don't like automatics.  This is way better/more fun to drive.
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #10 on: September 29, 2011 - 08:41:47 AM »
earlier versions may not have added the extra piece that you need to install on the right side of the tunnel in conjunction with the 4 spd hump. gives more clearence for the square body of the trans.
Mopar Dave
73 F8 Challenger
1990 XJ - sold
