Author Topic: Who Sells MOPAR Speedo Cables?  (Read 4010 times)
Offline challengermaniac
« on: September 27, 2011 - 11:13:15 PM »
Where can I get a MOPAR Speedo Cable?  Dave at roseville has them on back order----- not sure what the eta is.  Any other suggestions?  Please provide Web address and/or company name.  (Must be Mother MOPAR, not an aftermarket).  Thanks
Charlie
70 Challenger 340/4 Purple
70 Challenger T/A Red
Edmonds, WA
Offline Cuda Cody
  • Vancouver, WA
Re: Who Sells MOPAR Speedo Cables?
« Reply #1 on: September 28, 2011 - 01:12:25 AM »
Dave just sent me one so he might have had some come in.  It's perfect too!
Stay away from Year One as I've seen one and it's not very good.
« Last Edit: September 28, 2011 - 11:43:10 AM by C O D Y »
« Reply #2 on: September 28, 2011 - 08:08:46 AM »
Mine failed about a month ago so Dave has one put aside for me, but I'm 90% sure I'm going with a Keisler auto OD set up and it comes with a new cable. I'll PM Dave and tell him to send it to you if that works for you?
Offline JayBee
« Reply #3 on: September 28, 2011 - 09:33:39 AM »
What a coincidence that this topic was started. I went to my local dealership (St. Catharines, ON) and gave them 2 part numbers - 2889783 & 4897646AA. They said it's no longer available through the dealer. Every Google search I've read said that it WAS still available at "Mother Mopar". So, is it just that us Canadians can't get it in Canada? Sorry challengermaniac that this wasn't any help but I'm kinda curious about this too.
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #4 on: September 28, 2011 - 10:29:34 AM »
Charlie, i have one for you.
JayBee, not sure why chrysler canada give you guys the run around, they are on back order across the board. here is a dealer that does show one. not sure if they will give it up.
part number 4897646AA
  KIM'S CHRY-PLYM-DODGE & JEEP   LAUREL   MS  USA  Phone:   (601)-425-4788   /   (601)-425-4701
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
« Reply #5 on: September 28, 2011 - 11:40:26 AM »
Thanks Brad & Dave.  I accept!
Charlie
Edmonds, WA
Offline GranCuda1970
« Reply #6 on: September 28, 2011 - 11:48:13 AM »
Question for Dave
    I am switching from auto 318 to manual 440 with a Holly 750 will I need a new cable or will my old 318 cable work? If not I will need to get one.
« Reply #7 on: September 28, 2011 - 12:19:31 PM »
Question for Dave
It will work , the speedo drive  is the same & in the same location
« Reply #8 on: September 28, 2011 - 12:21:02 PM »
Thanks Chryco  :2thumbs:
« Reply #9 on: October 08, 2011 - 06:38:22 PM »
Do I have the correct replacement speedo cable?  As in how does the top cable end fit on to the back of the speedo gauge and do the 2nd & 3rd pics look correct for the speedo cable going into the trans?
Charlie
Edmonds, WA
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #10 on: October 10, 2011 - 04:28:16 PM »
this is the ONLY cable. the upper pushes onto the  speedp housing stem and the tab grabs the ridge and holds it,  with the lower the center is like a rectangular end and that goes into the end of the pinion, then you thread the nut on,
Mopar Dave
73 F8 Challenger
1990 XJ - sold
Offline DMZ73
    • http://www.pbase.com/dmz73/
« Reply #11 on: October 13, 2011 - 08:46:47 PM »
Funny this comes up again, just when I'm looking for the same input...
I bought my cable a few years back at an Autozone, or whatever...
Went and hooked it up, and didn't get to drive the car till after pulling the IP again.
Upon install, I had a devil of a time under the dash putting the cable back in with the "clip"
But once I got it on, all seemed well and good.
Took it for a test drive and nothing.
Went to remove the cable, and that clip broke, rendering whatever cable I had useless.
Is there a higher quality one out there that is available?
What could be the reason it didn't work?
Serves me right from not buying it from Ma....
Dan
Offline jimynick
« Reply #12 on: October 13, 2011 - 10:26:43 PM »
You may have missed the part where they described the inner cable as being SQUARE. Put the top connection on first which allows you to spin the bottom end to make sure the cable goes in the square hole smoothly and then index the bottom end to match the orientation of the square socket in the trans and make sure it goes in smoothly before threading the nut on. Chances are that you jammed the cable in one of the sockets and bound it so it wouldn't/couldn't turn. A touch of Lubriplate is also a good thing on the ends of the cable. Good luck
