Author Topic: vapor?  (Read 1100 times)
Offline Scat Pack Fever
  • Mopars Rule!!!!!!!! Always Have, Always Will
  • Chrysler did it best!
vapor?
« on: September 28, 2011 - 04:17:23 PM »
I started my challenger up yesterday and noticed that vapor was comming out of the passenger side exhaust. I know it isn't smoke because it dissappears about a foot from the tail pipe. I din't leave it running long enough to tell if it was going to stop. Does anyone know what might be causing this? I am concerned that it is only comming out of one pipe instead of both.
Re: vapor?
« Reply #1 on: September 28, 2011 - 04:44:49 PM »
Probably just some water evaporating from the system.  The last time the engine was started(prior to you just starting it) how long did you run it?  Do you have a working heat riser in the passengers side exhaust manifold?  Do you have any weep holes in the back of your mufflers at the lowest point?
Offline Super Blue 72
    • Phil's Super Blue '72
Re: vapor?
« Reply #2 on: September 28, 2011 - 06:45:37 PM »
IF it is ONLY water vapor, I wouldn't be too concerned...I think....  :sly:
Like burdar said, it could be water evaporating from the sustem.  Could be condensation also from a cool night.  Also, water vapor is actually a good by product of complete combustion of a hydrocarbon.
Is your carburator adjustment screws adjusted equally?  Just a thought...
Re: vapor?
« Reply #3 on: September 28, 2011 - 08:04:41 PM »
It had been a while since I started it. No heat riser, I have headers. Not sure about the weep holes. I am running flowmasters. My biggest concern was a blown head gasket.
Re: vapor?
« Reply #4 on: September 28, 2011 - 08:05:49 PM »
No sure on the carb screws. I'll check that. I live in St. Louis Mo and it has cooled off quite a bit over the last few weeks.
Offline PlumCraZRT
Re: vapor?
« Reply #5 on: September 29, 2011 - 06:58:32 PM »
Check to see if you have water in your oil.  If there is no water in the oil and the fluid levels are good, there will be no harm to the engine.
mmmmm.... Mopar.... *drool*
Offline Grec
Re: vapor?
« Reply #6 on: September 30, 2011 - 07:34:51 PM »
It's pretty normal for cars to let out vapor on startup. Especially older, less emissions-regulated cars. (I believe it has to do with water condensation in the exhaust system.) I know mine does if she's sat for awhile.
Not sure if this has any bearing on your situation, but mine used to put out more vapor from one side of the exhaust until I did some tuning and sealed the headers really well.
Now I have much more balanced vapor... when I get it.
1973 Challenger Rallye
- 440 Six Pack
- A833 4 Speed, 18 Spline
- FE5 Rallye Red on Black
Offline Cooter
    • christinecarclub.com
Re: vapor?
« Reply #7 on: September 30, 2011 - 09:22:56 PM »
I wouldn't be too concerned about a blown head gasket. I'd be more inclined to believe condensation in the exhaust that clears up after it's run till warm up...Try cracking on the engine after a little heat is in it and see if water flies out the tailpipe. If so, Then you have your answer....
