Author Topic: 4 Speed Console Template on Ebay: Any Good? Advice Appreciated  (Read 1115 times)
Offline Road_Runner
« on: September 30, 2011 - 12:29:03 PM »
Even though I haven't 100% decided to change over to a manual, I'm picking up the necessary pieces a little at a time.  I've got a nice auto console I can use, but before I start cutting/grinding on it with my dremel tool I figured I'd check here to see if the templates being sold on Ebay are any good, and see if anyone who's done it has any hard-earned lessons they could share.  I really don't want to screw this up so any advice would be greatly appreciated.
Thanks, Jim
1970 383 Roadrunner Tor Red
1973 318 Barracuda Mist Green
Offline Grec
Re: 4 Speed Console Template on Ebay: Any Good? Advice Appreciated
« Reply #1 on: September 30, 2011 - 12:41:34 PM »
I didn't get the template from Ebay, but I did get one from a member here years ago and it looked to be the exact same pattern.
I converted my console a few months ago and it worked perfectly. The one trick was getting a cutting tool that goes fast enough to cut the plastic vs. simply melting it's way through it. ie a Dremel with a cutting bit won't cut it, so to speak. I cut a small piece out of the console in the area I knew would be removed and tested with a couple tools before I found what worked. I can'f for the life of me remember what the winning one was called though, unfortunately. Was router-like though. Spinning bit that just cut through.
The way I transfered the pattern to the console was to cut it out and carefully outline the pattern with tape. Then simply cut along the inside edge of the tape line.
Once that was done, I went in and smoothed out the cut lines. Looks great in the car and only the most observant / knowledgable mopar heads would be able to spot it. :-)
Hope this helps!
1973 Challenger Rallye
- 440 Six Pack
- A833 4 Speed, 18 Spline
- FE5 Rallye Red on Black
Offline Road_Runner
« Reply #2 on: September 30, 2011 - 01:09:20 PM »
... removed and tested with a couple tools before I found what worked. I can'f for the life of me remember what the winning one was called though, unfortunately. Was router-like though. Spinning bit that just cut through.
Rotozip maybe?  I've got one of those too, but was hoping the dremel would do the trick because I've used one for years.  Never used the Rotozip for anything other than bathroom tile.  Thanks for the great feedback!
Later, Jim
Offline daveh
« Reply #3 on: September 30, 2011 - 04:46:28 PM »
This will do the trick just great.  I've used it on plastic dozens of times.  Use a fine toothed blade.  Just take your time or it can get away from you quickly.
I was also looking for that template if anyone has it please let me know.  Thanks
http://www.harborfreight.com/high-speed-metal-saw-91753.html
Offline Katfish
  • 70 Challenger
« Reply #4 on: September 30, 2011 - 04:59:54 PM »
I would think the dremel tool should work, plenty of RPMs.
Just get the right cut-off wheel and practice 1st.
Offline the_engineers
« Reply #5 on: October 01, 2011 - 07:05:52 AM »
Use tape as suggested above and the melted flash from the Dremel should break off pretty cleanly.
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
