Author Topic: Turn signal flasher -LED  (Read 2499 times)
Offline Lockout76
  • Everything's a project...
« on: September 30, 2011 - 06:04:19 PM »
Hey all,
Need some quick help with my LED front turn signals. I'm installing a LED flasher unit to stop the quick flashing that LED's do with a normal flasher unit.
Car is a 74 Cuda, Rallye Dash, and original flasher unit works with no problems.
I got the two prong Grote 44891 http://www.summitracing.com/parts/GTE-44891 to replace the original unit, The Grote is made for LED's, original is just a stock flasher.
Aftermarket fits like original, only thing different is the white wire coming from the top. The flasher unit plugs into the factory connection with a red power wire and a black ground like the original.  I grounded the white wire coming out of the top unit (several different locations) and nothing works. The Tech line stated it was a ground wire and sent me a new unit as he thought prior flasher was bad. Same thing with new flasher, no turn signals.
If the white wire is a ground, why would the new unit need a second ground?
Any ideas on how to get the flasher to work?
Thanks, Mike
-1974 'Cuda 340, 4-speed, 3.55 Sure-Grip.
Offline GoodysGotaCuda
Re: Turn signal flasher -LED
« Reply #1 on: September 30, 2011 - 07:12:13 PM »
Not sure the resolution to your problem, however I did cover this off-the-shelf flasher replacement that works with LED tail lights in my 'Cuda. Direct swap
http://blazer-international.com/products/Flashers/Flashers/FL32
http://www.cuda-challenger.com/cc/index.php?topic=67744.msg695422#msg695422
Hope that helps if you can't figure the other flasher out.
-Mike
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline Lockout76
« Reply #2 on: September 30, 2011 - 09:52:06 PM »
Thanks Goody,
I figured it out after searching google for a while and found a random link. Its appears that the turn signal system doesn't create enough amps to work that LED flasher, New flasher has a 1 amp min. I bought one kinda like yours from a local auto parts store, Tridon EL12. Works perfect.
Thanks again,
-Mike
« Reply #3 on: September 30, 2011 - 10:53:28 PM »
Thanks Goody,
Thanks again,
-Mike
Glad to help!  :wave:
1976 Dodge Warlock
