Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Transmission and Drivetrain
(Moderator:
Chryco Psycho
Reverse Problem
« previous
next »
Print
Pages: [
1
Author
Topic: Reverse Problem (Read 853 times)
300
Jr. Member
69 chevelle,67chevelle , 70 barracuda
Reverse Problem
on:
October 01, 2011 - 07:39:22 PM »
Just installed my Pistol Grip shifter on my 883, Trans is on bench out of car,, i can go 1-2 and 3-4 using Handle, but can,t go reverse, only when i manually move rod, Is there something i,m missing here Thanks
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: Reverse Problem
Reply #1 on:
October 01, 2011 - 08:33:31 PM »
you may not have the levers centered in the shifter , you can adjust the rod length to get all tree levers centered , there is a notch in the bottom of the shifter body & holes through the 3 levers , you can insert a drill bit or similar to line them all up & adjust the rod lengths from there . if the levers are not lined up the shifter will not move into tthe reverse gate
Logged
300
Jr. Member
Re: Reverse Problem
Reply #2 on:
October 01, 2011 - 09:12:31 PM »
Thanks Chryco, would the leverson trans for 1-2 and3-4 be up and down and reverse at angle around 2 o'clock to do this adjustment , also this notch in bottom what do i look for here Thanks
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: Reverse Problem
Reply #3 on:
October 01, 2011 - 09:27:59 PM »
disconnet the levers from the side of the trans & center the levers in the shifter , you can slide a drill bit through the holes in all 3 levers when centered , then adjust the rod lenght so the levers fit on the trans , Sorry I do not have an y pix handy
Logged
300
Jr. Member
Re: Reverse Problem
Reply #4 on:
October 01, 2011 - 09:43:02 PM »
Got you now With That in mind, When the shifter is at rest i can push it forward to 3 back to4, then i pull handle to the left and i can do 1 and 2 But should,nt i be able to pull it more to the left so i can push it forward into Reverse That is what i can,t do Trans has been rebuilt, new rods, Hurst Comp has not ?
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: Reverse Problem
Reply #5 on:
October 02, 2011 - 08:05:37 AM »
Yes reverse is one more gate to the left
Logged
300
Jr. Member
Re: Reverse Problem
Reply #6 on:
October 02, 2011 - 03:55:32 PM »
Got it CP. Thanks. Short Travel Between 1and 2. ah
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: Reverse Problem
Reply #7 on:
October 02, 2011 - 11:26:06 PM »
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
Reverse Problem
