Author Topic: any tricks to removing carbon buildup on valves  (Read 4184 times)
Offline black71
  • eph 6:12
« on: October 02, 2011 - 03:28:27 PM »
..... cause wow they are dirty...pulled apart a set of 452...time for some new seals and what not, gonna check the valve seats while i'm at it jus need to know a good way of getting the deposits off...
Re: any tricks to removing carbon buildup on valves
« Reply #1 on: October 02, 2011 - 03:33:22 PM »
This what my automotive teacher years ago showed us in class:
Pour Marvel Mystery oil slowly down carb while the engine is running. DO NOT let the engine stall.
Keep hand on throttle linkage and increase slightly as you are pouring it in.
Now whether his claim is accurate on removing deposits is true or not; I have no proof on his theory/experience/demonstration is factual or not.
When apart use brake cleaner.
« Reply #2 on: October 02, 2011 - 04:21:40 PM »
Take it for a run at WOT.
Offline GranCuda1970
« Reply #3 on: October 02, 2011 - 04:31:59 PM »
I had a friend who would pour a little water in the carb while it was running and throttle it up, said it would clean the carbon off. I thought he was crazy but it did not kill the engine or anything.
Offline dutch
« Reply #4 on: October 02, 2011 - 04:35:38 PM »
last year we had a good thread on the matter...
http://www.cuda-challenger.com/cc/index.php?topic=68617.0
*** Bart ***
« Reply #5 on: October 02, 2011 - 04:38:19 PM »
That's what I would have suggested too. I had a water injection kit on an engine once to prevent detenation. It worked great, also kept it all clean as a whistle!
Doesn't do you much good when the heads are off though...
Offline dutch
« Reply #6 on: October 02, 2011 - 04:41:27 PM »
ah...  the heads are off....  :bricks1:
*** Bart ***
« Reply #7 on: October 02, 2011 - 04:46:13 PM »
This is true!!
Offline 72cudamaan
« Reply #8 on: October 02, 2011 - 05:59:20 PM »
 :iagree:  Works like steam cleaning.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline jimynick
« Reply #9 on: October 02, 2011 - 10:05:03 PM »
Don't know what others use, but a wire wheel on a bench grinder does a fast and thorough job for me. Wear eye and hand protection and 16 minutes later, you'll have clean valves.   :thumbsup:
Offline 72cudamaan
« Reply #10 on: October 02, 2011 - 10:28:29 PM »
 Oh, thats totally different. Never mind.
Wire wheel lightly. And if you're not grinding the valves or seats, make sure you put
the valves back in the same spots.
Offline Chilly
« Reply #11 on: October 03, 2011 - 02:35:03 AM »
I used old carb cleaning solvent that I used to soak carbs in before rebuilding them.
Offline Aussie Challenger
« Reply #12 on: October 05, 2011 - 07:19:11 AM »
Yes a wire wheel will clean them up but don't forget to do the ports & combustion chamber. While it is apart I would also do the vales & seats, don't forget to check the valve guides first. In other words while it is down and apart do it right and the heads will give you many peaceful and reliable miles.   :working:   :bigsmile:
