Hope this helps.
It's certainly helpful!
If you hadn't told me about this, I'd be thinking everything was fine, and then be hit with these problems again.
The dashboard harness is already scheduled to be replaced, and so is the harness/switch assembly for the steering wheel.
I'm going to replace all the old wires, all that brittle insulation is a disaster waiting to happen.
Also a new alternator with a internal voltage regulator is in the near future plans for the Chally.
Btw, I was measuring the voltage with the engine running, would that make a difference?
Right now, the car is in winter storage, and I'm on my way to Angolan waters for five weeks of work at sea.
But I will certainly look into this when I come home, so I can order a new ignition switch if need be.
