Author Topic: LED rear lights for 73 challenger??.  (Read 4407 times)
Offline Sonnythebull
« on: October 05, 2011 - 08:05:55 PM »
Need some help finding the led taillight kit for 73 challenger. The one that goes in to the socket where the bulb goes. Any advice?
Offline 73EStroker
Re: LED rear lights for 73 challenger??.
« Reply #1 on: October 05, 2011 - 11:56:28 PM »
If you are talking those multiple LED bulbs then they are useless as they shine up not back towards the rear of the car. I just use higher wattage standard bulbs. No one has come up with a lamp that works. There is, however, previous posts here about a complete LED conversion that was done for a 70 Challenger though. That might work. My car is Citron Yella so no one is going to hit it in daytime and the tailights are reasonably bright at night.
Barry (Salmon Arm)
Offline Ornamental
  • Oslo, Norway
« Reply #2 on: October 06, 2011 - 08:24:04 AM »
I guess you're looking for something like this:
http://www.hitechledproducts.com/product_info.php?cPath=26_84&products_id=382&osCsid=9c026da0ba5568ac6de372f1476ce20b
It's plug and play, remove bulb, install kit. No hassle with any kind of modifications of the wiring in any way. You can remove the kit and go back to using a bulb if you wish, no problem.
Panther Pink '72 Challenger Rallye.
Grey '70 Challenger R/T
-There are two kinds of pedestrians: The quick and the dead.
***Per Arne***
Offline azievinger
  • one Happy Island
« Reply #3 on: October 06, 2011 - 09:05:51 AM »
Our you can try this : see also other $50 led thread
Thank you for asking about our 1972 thru 74 Challenger LEDs.
We have changed our company name to ClassicLEDs as we now
offer the largest line of Mopar LEDs on the market today along with
numerous other lines other then our Mustang line.
The 72/74 Challenger LED brake light contains 92 Red 5mm Super
Bright per board for a total of 184
Reverse lights contain 34 White 5mm Super Bright LEDs per board
for a total of 68.
The non sequential plug into the OEM socket using our 1156/57 bulb
socket based wire harness.
Sequential LEDs contain a small computer control that taps into the
OEM wire harness. This control contains a small button allowing you
to stop or re start the sequence at any time.
There is no modifications to your wire harness.
Pricing:
Brake Only $ 89.95
W/Reverse LEDs 154.95
Sequential $ 135.95
W/Reverse 199.95
All our LEDs systems come with a LIFETIME WARRANTY to the original owner.
ClassicLEDs is a small family owned business. We manufacture all our products here in Eugene,
Oregon.
there contact info :
Lawrence M Bush
ClassicLEDs LLC
WWW.NorthWestMustang.COM
3128 Marvin Dr.
Eugene, OR 97404
541.463.7623 OP
541.505.7513 Fax
541.554.4751 Cell
email: NorthwestMustang@comcast.net
« Reply #4 on: October 06, 2011 - 09:11:09 AM »
Thanks very much
Offline bigblue73
« Reply #5 on: October 06, 2011 - 09:58:17 AM »
for a total of 68.
Pricing:
Brake Only $ 89.95
Sequential $ 135.95
W/Reverse 199.95
Oregon.
Lawrence M Bush
ClassicLEDs LLC
3128 Marvin Dr.
Eugene, OR 97404
541.463.7623 OP
541.505.7513 Fax
541.554.4751 Cell
X2 on the product from Northwest.  I have them installed in my car and they are excellent.  Be prepared to do a little grinding on the edges to make them fit properly into the lens.  The 72-74 challenger units are actually from his 69 Chevelle boards just routed different.  Good stuff and very bright.
Offline moparmaniac59
  • Drive it like ya stole it!
« Reply #6 on: October 06, 2011 - 12:10:04 PM »
Sounds good. I actually got pulled Memorial Day weekend because the officer said he thought my tail lights were too dim/defective. I showed him that they were fully functional brake lights/tail lights and told him that they were factory and that was as bright as they were going to get. He couldn't write me a ticket and I'm sure he rally just wanted to look at the car!! But I have wanted something a little brighter! Thanks for the data!  :2thumbs:
        Matt B.
Matt
Offline Ornamental
  • Oslo, Norway
« Reply #7 on: October 08, 2011 - 11:15:14 AM »
 :roflsmiley:
Got any pictures of it?
Curious on how the boards aand mounting bracket looks, and how it fills out the lens, The kit from hitechled is very... ...square.
***Per Arne***
Offline bigblue73
« Reply #8 on: October 13, 2011 - 09:07:16 AM »
Installation is simple.  Remove the taillight lens to expose the bulb.  Remove the bulb and socket from the housing.  Press down and twist to remove the bulb from the socket.
Before installing the LED taillight boards, look at your taillight lens gaskets and make sure they are in good shape and replace them if needed.  With LED tail lights, water is an enemy.
Trial fit the LED boards to the inside of the tail lights lens.  They must fit inside the tail light lens housing.
The LED board has an 1157 pigtail mounted to the back of the board which simply plugs
in the existing wiring harness.  No modifications to the original wiring are required.
The LED board is held in place with 3M Brand VHB tape.  This tape offers excellent adhesive that develops over time.  This stuff is tough.  If a less permanent adhesive is desired you can always using a silicon caulk adhesive.
The installation is simple and can be done in about an hour.  For the sake of safety this entire installation costs less than $100.00 total, which is money well spent.
« Last Edit: October 13, 2011 - 11:27:58 AM by bigblue73 »
Offline azievinger
  • one Happy Island
« Reply #9 on: October 13, 2011 - 09:18:45 PM »
nice info and pics, know now what to do, mine where shipped today, anxious for them
Offline Jamiez
  • Retro
« Reply #10 on: October 22, 2011 - 07:10:53 PM »
My set just arrived today.  I didn't put them in permanently, but I mocked them up.   Before I did I pulled out my light meter and took some readings:
Before:
Brake: 90 lux
Running lights: 54 lux
After:
Brake: 1410 lux
Running lights: 70 lux
I ordered the reverse lights as well but I haven't put them in yet.
Offline azievinger
  • one Happy Island
« Reply #11 on: October 23, 2011 - 12:52:04 AM »
waiting for my set to arrive, made it to miami need the last part to aruba, will be somewhere coming week.
thx for the info
