Author Topic: 1968 BARRACUDA FASTBACK FOR SALE  (Read 8817 times)
Offline STAINLESS1
  • I love YaBB 1G - SP1!
    • MMS & ACCESSORIES
« on: October 06, 2011 - 03:46:36 PM »
 :wavingflag:
1968 Barracuda Fastback for sale- need to sell ,moving to apartment in CAILF . TO BE CLOSE TO DAUGHTER AND GRAND DAUGHTER--
EVERY THING NEW- NEVER STREET DRIVEN-
CHECK THIS SITE FOR ALL INFORMATION
LOCATED IN RYDAL, GA - 1 HR NORTH OF ATLANTA
http://www.mmsacc-stainless.com/html/barracuda.htm
Prowler flame orange pearlcoat
   ENTIRE CAR BLASTED (on whirly -jig)- NO RUST
   BASF PAINT
   GHOST FLAMES FRONT FENDERS
   RECHROMED BUMPERS
   RECHROMED DOOR HANDLES
   STAINLESS STEEL DOOR LATCH
   AIR OPERATED HOOD
   FIBERGLASS 6 PACK HOOD
   STAINLEES TILT COLUMN
   FLAME STEERING WHEEL
DRIVER & PASS ELECTRIC WINDOWS
   5 POINT PENTA FENDER BOLTS
   CHROMED HOOD HINGES
   NEW INTERIOR
   NEW RUBBER
    NEW CARPET
   NEW HEADLINER
   NEW GAUGES
   NEW ALPINE CD
   NEW FRONT GLASS
   STAINLESS STRIKERS
   NEW AC/ HEATER-STAINLESS LINES
   NEW FUSEBLOCK AND WIRING
   440 EMBLEMS ON SIDE OF CAR
   DUEL 12 VOLT BATTERIES IN TRUNK
   ALUMINUM RADIATOR
   PENTA STYLE OVERFLOW TANK
   SPECIAL MADE ALUMINUM ELECT FAN
TIRES & WHEELS
   FRONT- FLAME WHEELS
      15 X 6
      215-15 X 60 BF GOODRICH
   REAR- FLAME WHEELS
      15 X 8
      295-15 X 50 BF GOODRICH
ENGINE:
   Boiled & de-greased block
   Magnafluxed block
   Bored block - .030
   Honed Cylinders with honing plate
   R&R Cam Bearings
   R&R Freeze Plugs
   Regrind Crank 10-10 & Polish
   Recondition FORGED Rods - new rod bolts
   R&R Rods on Pistons - Forged Pistons 10.1 Compression
   Balanced Complete Assembly
   DOUBLE TIMING CHAIN
   CRANE HYD CAM  #643801
   HIGH VOLUME OIL PUMP
   BARRY GRANT CARBS- 650 DOUBLE PUMP- 2 EACH
SPECIAL MADE AIR CLEANER
   CUSTOM MADE INTAKE
   VERTEX DISTRIBUTOR / 10MM WIRES
   STAINLESS DIST HOLD DOWN
   STAINLESS VALLEY PAN HOLD DOWN
   CUSTOM MADE VALVE COVERS
   CUSTOM MADE FUEL LOG- ALL STAINLESS
   ALUMIMUM WATER PUMP & PULLEYS
   CUSTOM MADE ALUMINUM BRACKET FOR A/C & ALT (CHROME ALT)
   STAINLESS 2 1/2 MUFFLERS
   HEADERS -TTI
TRANSMISSION:
   727 RB Transmission
   Heavy Duty 4 Clutch Pack
   High Powered Drum
   Semi-Metallic Friction Bands
   HP intermediate low band
   5-0 Ratio
   Reinforced band struts
   4 pinion input planetary gear
   Hardened Input Shaft
   Modified Valve Body and Governor
   Improved Lube Oil Circuits
   3000 STALL CONVERTER
   STAINLESS TRANSMISSION MOUNT
   ALUMINUM DRIVESHAFT
UNDER CARRIAGE:
   ALL NEW COMPONENT FOR FRONT END
   MAJOR PIECES- POWDER COATED BLACK
   NEW QUICK RATIO STEERING BOX
   COIL OVER SUSPENTION
   STAINLESS STRUT RODS
   SUB FRAME CONNECTORS
   NEW DANA 60  Strange 35 Spline Axles with 5 X 41/2 bolt circle,
   new Spicer 3.54 gear ratio, Spicer Traclock Posi, new 1350 series yoke,
    all new Timken Bearings and Seals.
   LARGER CAPACITY REAR END COVER
   LADDER BAR REAR
   All 4 stainless brakes--(stainless brake corp)
   ALL NEW STAINLESS BRAKE LINES
   STAINLESS FUEL TANK
   NEW ELECTRIC FUEL PUMP & FILTER
   STAINLESS FUEL LINES
BARRACUDA@MMSACC-STAINLESS.COM
770-547-7386
770-386-5772
« Last Edit: October 07, 2011 - 03:14:37 PM by STAINLESS1 »
