Author Topic: Leaky Main Seal Leak on Stroker Motor  (Read 783 times)
Offline hemidude426ci
« on: October 08, 2011 - 06:22:39 PM »
So, the crank in my 440-6 that was stroked to 500 CI is habitually leaking.  It seems like the crank that has been a pain since day one, is eating away at several main seals.  Any quick fixes short of pulling everything apart and putting in an asbestos main seal?
1970 FC7 440-6 'Cuda 4spd  Track Pack N96
Gone:
1970 Challenger R/T 440 6pack 4 spd N96
1970 Superbee 440 6pack 4 spd
1967 Shelby GT350
Re: Leaky Main Seal Leak on Stroker Motor
« Reply #1 on: October 09, 2011 - 10:50:27 AM »
sounds like the seal surface on the crank in not smooth , I guess you have swapped the seal a least twice so far , the seal retainer could be milled down a few thou to tighten the clearance for the seal & inspect the crank surface while in there or the seal plate could be replaced with the new billet type . I assume the seal lip is pointed inward to wards the oil
Offline BadJoey
« Reply #2 on: October 12, 2011 - 07:39:40 PM »
Are you sure it is the seal ? My gasket set came with pipe cleaners and a tube of form a gasket crap for the seal cap . Changed it to a carboard gasket and leak was gone . :popcorn:
