.. Never any smoke before the change, and I always put 93 octane in it, yeah the motor burns some oil, but most big blocks will burn a little, I changed the plugs anyway it couldn't hurt... I'm hoping that this motor can make it with out a rebuild a while longer! I'm just doing all I can to make it last. Here's the results of the compression test: Over all the compression is not too bad, they are all 180 PSI or above
Cyl #1: 180 PSI
Cyl #3: 180 PSI
Cyl #5: 180 PSI
Cyl #7: 190 PSI
Cyl #2: 190 PSI
Cyl #4: 195 PSI
Cyl #6: 180 PSI
Cyl #8: 195 PSI
