Author Topic: Power steering bracket/belt-tightening bolt  (Read 872 times)
Offline jforest1
« on: October 10, 2011 - 04:30:00 PM »
I took it out, because the washer was cone-shaped from over-tightening, as well as the bracket, so that it sat in one spot and could no longer be adjusted.
It took 3 hours to get it out because the thread gaps were all filled with ?hardened oil gunk?.  Once out, coolant spilled out (bolt went through water jacket I suppose) and I cleaned the bolt and threads.  I haven't put the bolt back in yet as I have yet to get the new washer (been 3 days or so now).  What I found was that as coolant came out, it was dark (I suspected engine oil also mixed in).   After cleaning the bolt off, and ran it in and out a few times to clean up any further gunk and sure enough approx. a teaspoon of oil came out with each insertion/removal.
Have I ruined my engine by getting oil in the coolant or vice versa?  What should I have done and what can I do now?  Or is this all normal and I should just shove the bolt back in and fire it up?
Thanks guys!
JF
'73 Cuda 340 Slapstick, A727 Torqueflite Transmission, Edelbrock Thunder Series AVS 1806, Vintage Air Gen IV A/C system
Re: Power steering bracket/belt-tightening bolt
« Reply #1 on: October 10, 2011 - 06:17:13 PM »
small block or big block ?
 on the big block the bolt goes into the water jacket & there is nowhere to get into the oil , on the small bloch it is possible for water to get into the oil between the timing cover & block , the gunk in the water could just be sludge in the cooling system not oil . if you are concerned just remove the oil drain plug , water will come out first if there is any in the oil system , ti will not ruin the engine as long as it is drained out
Offline jforest1
« Reply #2 on: October 12, 2011 - 12:43:06 PM »
Thanks.  Looks like no coolant in the oil.  Thanks for the tip!
JF
