Author Topic: Rallye Guage Fascia 73 Challenger (3 Switch)  (Read 3952 times)
Offline challenger_73
« on: October 12, 2011 - 02:56:10 PM »
Does anyone know where I can purchase this?
challenger_73
Re: Rallye Guage Fascia 73 Challenger (3 Switch)
« Reply #1 on: October 12, 2011 - 04:41:21 PM »
PG Classics...BE&A...Roseville...all sell the same woodgrain.  PCG(Performance Car Graphics) sells one of their own.
There are differences between the two.  The panels that Roseville sells are shipped flat and you have to bend the edges yourself.  You also have to reuse the thick metal backing that is behind the original woodgrain.  The PCG part comes prebend and also comes with new thick metal backing already attached.
The PCG parts are the closest thing to original on the market but have a couple fitment issues that I've heard of.  They are also a lot more expensive then the ones Roseville sells.
The PG Classics/BE&A/Roseville fascia looks nice but isn't factory correct looking.  The brown paint around the gauges isn't the right color...the woodgrain isn't exactly right and I had some fitment issues as well.  Depending on when your 73 was built, the switch panel might not be worded correctly either.
Sometime in 73, the switch panel wording was changed and little "headlight" and "washer" symbols were added next to the switches.  My original Oct 72 built 73 fascia doesn't have any of those symbols and says HEAD LAMPS under the light switch.  The PG Classics panel just says LIGHTS.
« Last Edit: October 12, 2011 - 05:01:48 PM by burdar »
« Reply #2 on: October 12, 2011 - 04:55:33 PM »
Thanks. That helps. Would you or anyone know whom makes the fascia for the Chrysler dealerships? I found out that they can order it at the dealership. I'm not sure of the quality though.
challenger_73
« Reply #3 on: October 12, 2011 - 05:01:20 PM »
Roseville is a dealer and he sells the PG Classics/BE&A woodgrain.  I don't think all dealers have access to the woodgrain unless MP lists it in a cataloge somewhere.
DMT(Detroit Muscle Technologies) sells a woodgrain overlay.(vinyl)  I know he has spent a lot of time trying to find a woodgrain pattern that matches the factory screen printing.  That may be an option for you.
Offline 73RallyeChallenger
« Reply #4 on: October 12, 2011 - 09:39:56 PM »
Yes, it is listed in the Mopar Performance catalogue. I  think it sells for around $300 around here through the local Dodge dealership. I was wondering who makes it too.
Offline Gumby
« Reply #5 on: October 16, 2011 - 11:12:53 PM »
Off topic, sorry don't want to hijack this thread - but could someone tell me what that round black circle on the right side in the bent area is or is for? It's been driving me nuts. Thank you.
{oo/-------\oo} In '69 I was twenty-one and I called the road my own. I don't know when that road turned into the road I'm on. Jackson Browne
Offline VTMopar
« Reply #6 on: October 16, 2011 - 11:51:35 PM »
When lit - it says "Fasten Seat Belts" - only on '72-'74 rallye dashes.....
VT Mopar
VT MOPAR
« Reply #7 on: October 17, 2011 - 07:54:59 AM »
I called around last week to find out which dash fascia Mopar Performance sells. I have been told that its PG Classics. I case anyone is wondering, there is alot of PG Classics stuff being sold through the MP catalogue.
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #8 on: October 17, 2011 - 05:04:27 PM »
all of these types of parts in the MP book "77"were supplied by BEA
the woodgrain kits now come with the metal backer, but they are still staight, Bending them really isnt an issue.
« Last Edit: October 17, 2011 - 05:15:59 PM by mopardave »
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline Gumby
« Reply #9 on: October 22, 2011 - 12:59:27 AM »
Thank you VT MOPAR! Mine must not be hooked up.
Offline Jamiez
  • Retro
« Reply #10 on: October 22, 2011 - 12:07:41 PM »
On the 74, there are 2 connectors per side to trip that light.  One connector comes out of a hole in the carpet under the seat (weight sensor) the other comes out near the trans tunnel and connects to the bottom of the seat belt.  The light only comes on if there is enough weight in the seat and the belt isn't fastened.
In 74 this also trips the seat belt interlock and will not allow the car to start.  I believe it also sounds the buzzer if it's still connected.
When it's lit it looks like this:
Offline Gumby
« Reply #11 on: October 22, 2011 - 10:40:24 PM »
Thank you for the detailed info Jamiez. For the life of me, I couldn't figure out what it was. Shop manual is hopefully on the way now.
