Author Topic: Oil pan clearance issues  (Read 1137 times)
Offline mach3107
« on: October 12, 2011 - 09:26:09 PM »
I need some help. I'm installing a 360 into my 73 challenger. The engine came with a deep oil pan with no name on it. When installed, the drag link bar hits the back of the oil pan when the car is turned 1/2 way left or right. I held a friends deep oil pan next to mine and they look very similar. Any input would be great
Offline the_engineers
Re: Oil pan clearance issues
« Reply #1 on: October 12, 2011 - 11:37:28 PM »
Is the drag link offset towards the pan, or away?
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Offline mach3107
« Reply #2 on: October 13, 2011 - 09:05:52 PM »
I'm not sure what you mean by offset but as far as I can tell the steering linkage looks stock
Offline Strawdawg
    • Vortex Buicks
« Reply #3 on: October 13, 2011 - 09:48:19 PM »
Search will give you a number of threads on this topic...here is a recent one  http://www.cuda-challenger.com/cc/index.php?topic=79657.msg801438#msg801438
Offline footin70rt
« Reply #4 on: October 14, 2011 - 12:01:05 AM »
What has caught my eye is the gap between the mount and block on the upper rear bolt. Cold this be the wrong mount? I'm used to looking at Big Blocks, but that gap isn't right.   :2cents:
Thomas
Driving the same 70 R/T since October 1985
Native of Bozeman, MT
Offline ntstlgl1970
  • T a c o c a t
« Reply #5 on: October 14, 2011 - 11:17:22 AM »
And also, it looks like the sump is positioned for a different chassis - it should sit more foward towards the K member
Offline mach3107
« Reply #6 on: October 15, 2011 - 01:29:32 PM »
the gap on the engine mount is a common issue when trying to find the correct mounts for a small block (from what I understand). I'm just going to fill it with a spacer.
I guess what I'm looking for is should I try and cheat the steering linkage or do I have to get a a new pickup and oil pan? If so, any suggestions?
