Author Topic: emergency brake handle retainer  (Read 1530 times)
Offline Kevin71
« on: October 13, 2011 - 11:15:37 AM »
Does anyone know where you can get the small plastic retainer that goes on the emergency brake release handle.  It holds the handle in place and holds a spring back?
Offline spamtank
Re: emergency brake handle retainer
« Reply #1 on: October 13, 2011 - 11:41:14 AM »
I was missing the same part.  I used a spare crimp clip used on brake shoes to keep the spring posts in.  But if you are looking for 100% correct, this won't help you.
Rick, Manchester, NH
1970 SE 383 2V AT Challenger
1977 M882/W200 Power Wagon
2013 RT Plus 6M
Offline Kevin71
« Reply #2 on: October 13, 2011 - 12:22:54 PM »
I actuallly used a valve stem cap.  Took a plastic one and drilled a hole in then sltit the side.  I don't how long it will be on there though.
« Reply #3 on: October 13, 2011 - 01:24:57 PM »
You could probably use a really small rubber grommet if you can't find the original plastic clip.  I looked on R/T Specialties website but didn't see the correct one.
« Reply #4 on: October 13, 2011 - 07:33:29 PM »
those always fail , I have used metal E clips & other innovations to hold the spring back
Offline Kevin71
« Reply #5 on: October 14, 2011 - 09:33:57 AM »
Spoke with R/T specialities and they didn't have one but thought the one for the hood latch release handle may work.  They are checking on it for me and are supposed to be in touch today.  By the way what is a E clip.
Offline spamtank
« Reply #6 on: October 14, 2011 - 10:01:59 AM »
E-Clip.  Should be called a Mopar Clip   :bananasmi
2013 RT Plus 6M
Offline Skunkworks Challenger
  • Mopars forever!
« Reply #7 on: October 14, 2011 - 10:53:20 AM »
I used a piece of nylon tubing.  I removed the handle and slipped on a 2" piece then heated the end near the spring so I could make a bulge larger than the spring to act as a retainer.  I left the tubing long enough to act as an anti-rattle cushion in the orifice that supports the rod near the handle.  Working perfectly!  PK
The Brewmaster
Offline ksierens
    • 70 Challenger Resurrection
« Reply #8 on: October 14, 2011 - 11:46:02 AM »
I used a wire grommet, though I don't remember where I got them, maybe RadioShack.  I just cut the end off, slit it, and pushed it over the rod and into the hole.
Kurt - SE Michigan
Offline HP_Cuda
  • Mopar or No Car!
« Reply #9 on: September 19, 2012 - 03:33:26 PM »
I know this thread is a bit dated but I wanted folks to know you can find a 1/4" bushing from Osh that is a great replacement!!!
The white piece is what you need, I left the remaining piece which works like a washer.
