What is needed to swap from 2 speed wiper motor to 3 speed?
Author Topic: What is needed to swap from 2 speed wiper motor to 3 speed?  (Read 1811 times)
Offline 6PKRTSE
« on: January 13, 2005 - 11:46:46 AM »
My buddy is installing a 440 sixpack shaker hood setup on his 70' Cuda.What is needed to swap from 2 speed wiper motor to 3 speed? Does anyone have all the parts for sale that thet are willing to part with?
1970 Charger R/T S.E. 440 Six Pack
1970 CHALLENGER R/T, 25.5 Cert, 528 Alum 16 plug HEMI twin turbo.
1970 Charger 500 S.E. 440 4 BBL.
1970 Road Runner 383 4 BBL
1996 2500 RAM 488 V-10 4X4
2012 Challenger R/T Classic
Offline HemiDog
  • Do not Assume!
    • Hemi Dog
Re: What is needed to swap from 2 speed wiper motor to 3 speed?
« Reply #1 on: January 13, 2005 - 12:49:13 PM »
The motor is obviously different and the wiper linkages are also different.  I would assume you would need a new switch, but am not sure if the wiring is different.  I am working on the same conversion but havn't got into the meat of it.  So far I have just purchased the linkage from smsauto.  They can modify the standard two speed linkage to be a three speed and I don't think it is a hard thing to do.
« Reply #2 on: January 13, 2005 - 05:39:59 PM »
the different switch is needed wiring should work
Offline miketyler
    • www.miketyler.net
« Reply #3 on: February 07, 2005 - 09:41:38 PM »
Was there a variable speed wiper option? I bought a LH dash panel with switches from another car. The wiper switch in it seems to be a 2speed + variable unit? If this is so, what do I have to do to convert my 2-speed setup over?
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Offline hemi71
« Reply #4 on: February 18, 2005 - 08:13:08 AM »
You need a switch for a 3 speed or variable speed wiper, and i'm pretty sure the linkage changes between the 2 speed and 3 speed. I have a complete setup minus switch i might be willing to part with, includes a good working wiper motor that will need to be detailed. Pm me if you are intrested.
