Author Topic: What should the rod to floating pin clearance be?  (Read 10803 times)
« on: October 14, 2011 - 05:56:41 PM »
Just measuring the clearance and I get .0012" to .0015" seems like too much to me?  :dunno:
Re: What should the rod to floating pin clearance be?
« Reply #1 on: October 14, 2011 - 08:03:50 PM »
I do nto have that spec in my head but it sounds close to me , you need a little room for oil & heat expansion
« Reply #2 on: October 14, 2011 - 09:33:46 PM »
Thanks! I sure hope it's right. I was just under the impression it should be like .0005" as it gets bigger/more clearance as it gets up to temperature?
Offline 72cudamaan
« Reply #3 on: October 14, 2011 - 10:14:59 PM »
typically it is .0006-.0009 Brad.  Should feel like a slight thumb pressure press fit.
If I cant fix it, it's broke
Andy  (phukker whither)
« Reply #4 on: October 14, 2011 - 10:19:47 PM »
 :faint:   That's what I was thinking? hummmm maybe time to phone Muscle Motors....
Offline jimynick
« Reply #5 on: October 14, 2011 - 11:38:10 PM »
I'd call the piston manufacturer Brad. They should be able to  give you chapter and verse.  :2cents:
« Reply #6 on: October 15, 2011 - 04:23:39 AM »
Just reading Muscle Motors web site ...they say clearances should be .0008"  to .001"
Offline PlumCraZRT
« Reply #7 on: October 17, 2011 - 05:19:53 PM »
You sure your micrometer is clean and zeroed?
mmmmm.... Mopar.... *drool*
« Reply #8 on: October 17, 2011 - 06:23:30 PM »
 yep, I can feel an ever so slight rock in the pin when in the rod.
Offline 72cudamaan
« Reply #9 on: October 17, 2011 - 08:41:37 PM »
Yep, rocking motion is toooo loose. You should have to push it through with your thumb.
« Reply #10 on: October 17, 2011 - 08:47:24 PM »
 :banghead:
« Reply #11 on: October 17, 2011 - 09:31:07 PM »
Looking around on Moparts, came up with these posts....
http://board.moparts.org/ubbthreads/showflat.php?Number=5835466
Offline jimynick
« Reply #12 on: October 17, 2011 - 11:09:08 PM »
Why not cut to the chase and invest a call to either Ray Barton or Hughes Engines and ask the simple question- how much? If you do the oven thing, don't forget to throw the pins in too and THEN measure them.  :2cents:
« Reply #13 on: October 26, 2011 - 12:58:14 PM »
So I called Muscle Motors and told them my concerns, they said leave it with us and we will call you back. That was at least a week ago with no phone call? Not getting a warm fuzzy feeling here... :sly:
I was thinking though.... the pistons can be used as either floating or press on as I understand it. So to my way of thinking the clearances on a floating set up should be pretty tight no? The reason muscle says they need to be at .0008" is so the rod won't seize on the pin,( see there web site) but if that happens ( which I can't see happening as the clearance gets bigger with heat?) then the wrist pin will just spin in the piston like a regular press on style no?  Am I missing something here? :dunno:
« Reply #14 on: October 26, 2011 - 01:10:32 PM »
the piston clearance to the pin should be the same either way as it floats in the rod & piston , in a floating system . You still have to fix the rod problem though .
