Author Topic: turn signals  (Read 655 times)
Offline Scat Pack Fever
  • Mopars Rule!!!!!!!! Always Have, Always Will
  • Chrysler did it best!
turn signals
« on: October 19, 2011 - 11:30:44 AM »
What do I need for the turn signals to work? I move the lever on my steering column and nothing happens. I have a new surnsignal unit in my column. Just wondering if I am missing something.
Re: turn signals
« Reply #1 on: October 22, 2011 - 09:51:36 AM »
assuming the arm is tight on the switch you need to test for power going up to the switch or a poor connection at the plug at the base of the column , you may just have a bad fuse even if it looks good , you can test with a test light o be sure you have power on both sides of each fuse
