I'm planning a sixpack 383 (or 400) build myself. I've already got the sixpack setup, but since you don't and if money is an issue, build the best motor you can especially the short block and then update with a sixpack and maybe better heads later on. Back when I ran mine in the 70's, I used several intake/carb setups and a good dual plane like the Ede RPM (DP4B back then) and decent carb would run very strong and not cost nearly as much as a complete sixpack setup. Good luck.
Later, Jim
