Author Topic: Question, when running a Milodon gear drive , do you use the oil slinger?  (Read 3726 times)
Just gathering parts for my 451" build.... wondering if I need one? :dunno:
Re: Question, when running a Milodon gear drive , do you use the oil slinger?
« Reply #1 on: October 22, 2011 - 09:45:29 AM »
all it does is keep excessive oil of the front seal but my machinist leaves them off saying the seal runs too dry with it in place
« Reply #2 on: October 22, 2011 - 10:14:19 AM »
That makes scence? My BB Buick had a rope seal on it, so in that case I can see the need for the slinger as the rope would always be wet with oil anyhow and keeping excess oil off it would be a good idea to prevent leaks I guess? With the newer Viton type seals maybe it's not so nessesary anymore?
Offline Skunkworks Challenger
  • Mopars forever!
« Reply #3 on: October 22, 2011 - 10:38:00 AM »
I thought the slinger was for oiling the timing chain.  PK
The Brewmaster
Offline Cooter
    • christinecarclub.com
« Reply #4 on: October 22, 2011 - 11:00:59 AM »
It is, as it performs two vital jobs from factory. I prefer to run 'em. Simply because if you don't and something happens, that will be one of your first questions...
« Reply #5 on: October 26, 2011 - 03:08:01 PM »
I do not use anything other than splash oil from the pan. some guys drill a small 1/16 hole in the lifter galley plug behind the cam geat to give some extra oiling.
So do you leave off the slinger?
Offline mopar12372
    • mopartech
« Reply #6 on: November 28, 2011 - 06:41:53 PM »
i would leave it on
RESTO PICTURES
Offline joelson6
« Reply #7 on: December 01, 2011 - 10:03:01 PM »
i've always used the slinger an never had problems
« Reply #8 on: January 11, 2012 - 12:11:00 AM »
Brad, my 520 has one on my Donovan, my 511 i'm building right now will have one on it to, it's also a milodon I just do it for lube purposes, I always thought. These are race engines tho. Prob don't need them.
« Reply #9 on: January 11, 2012 - 06:48:00 AM »
Thanks everyone! I bought a new one to go on!  :2thumbs:
