Author Topic: Under license plate rot  (Read 536 times)
Offline Jocigar
« on: October 27, 2011 - 09:36:19 AM »
How would you fix this?  the rest of the tail panel is in great shape.   I have two cars with same issue.  thx
Re: Under license plate rot
« Reply #1 on: October 27, 2011 - 10:38:36 AM »
You could patch it but you'd probably have less time in just replaceing the entire tail panel.  Besides...there's most likely some hidden rust that you can't see right now.   Strip the entire panel and see exactly what you have to work with.  :2cents:
Offline 72cudamaan
« Reply #2 on: October 27, 2011 - 12:16:11 PM »
 :iagree:  But I did just recently see that somebody
does offer a patch panel for that area.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline Giveitawack
    • ebay
« Reply #3 on: October 28, 2011 - 01:10:06 AM »
I had the same problem on my -70.
Ended up detaching the trunk lock bracket and the license plate "box".
Made a patch panel and welded in.
Sandblasted the license plate box, painted the hidden areas and welded it in.
There was rust under the tail lights, around many of the holes for the trim.
Patched all these areas.
Some leadwork and shaped the edges.
A lot of work but it looks OK.
« Last Edit: October 28, 2011 - 02:40:13 PM by Giveitawack »
