Author Topic: Ballast resistor wiring with electronic ignition?  (Read 8681 times)
Offline Tonefiend
  • '70 Challenger
    • Ian A. Guitars
« on: November 01, 2011 - 03:26:50 AM »
Ok here is my setup.  I have an electronic ignition setup and the 4 way ballast resistor.  It does not appear to be wired in accordance with the diagram. I want to re wire it correctly.  Should I be using a 2 way or 4 way ballast resistor?  Anyone got a diagram?
Here is a pic of my situation..
Offline hooD
  • detroit iron
  • Motor City Made Muscle
Re: Ballast resistor wiring with electronic ignition?
« Reply #1 on: November 01, 2011 - 04:29:00 AM »
not sure if this will help, maybe someone else can answer you better....good luck.
schematic
in person
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
Offline Tonefiend
  • '70 Challenger
    • Ian A. Guitars
« Reply #2 on: November 01, 2011 - 04:45:38 AM »
Thanks!  That is a good start!  I was hoping to see the manual for a '72+  I noticed there is a notch indicating the B.R. is directional.  I think mine is miswired and backwards too.
Offline burdar
« Reply #3 on: November 01, 2011 - 08:43:49 AM »
Is your ECU a 4 or a 5 pin?  I think the 4 prong ballast is only needed with the factory 5 pin ECU.  The 4 pin ECU's had the ballast integrated inside the unit.  You may only need a 2 prong ballast.  Someone correct me if I'm wrong.
« Reply #4 on: November 01, 2011 - 10:46:18 AM »
the 4 pin ECU needs only a 2 pin ballast to the coil or just use one side of the 4 pin , if the ecu is a 5 pin you need the wire to low voltage pin on the ECU , the other side of the ballast
Offline Tonefiend
  • '70 Challenger
    • Ian A. Guitars
« Reply #5 on: November 01, 2011 - 02:18:01 PM »
So you are saying to use a 2 prong ballast with a 5 pin?  I think mine is a 5 pin.
Offline burdar
« Reply #6 on: November 01, 2011 - 02:25:26 PM »
The factory ECU was a 5 pin and used the 4 prong ballast.  The newer aftermarket ECUs are a 4 pin.  Those only require a 2 prong ballast.
Offline Tonefiend
  • '70 Challenger
    • Ian A. Guitars
« Reply #7 on: November 01, 2011 - 02:54:26 PM »
 :2thumbs: Thanks I have the diagram for the 2 prong in my manual, I'll re wire it up accordingly.  Thanks for the help guys!
Offline tman
« Reply #8 on: November 01, 2011 - 03:32:50 PM »
Remove the harness from the ECU and show us the PINS........That will be your answer.
Offline burdar
« Reply #9 on: November 01, 2011 - 03:35:46 PM »
Also, do you know where you got the ECU you're running?  I'm looking for one that looks closer to stock then the one I have.  You could paint yours black and it would look pretty close.
Offline Tonefiend
  • '70 Challenger
    • Ian A. Guitars
« Reply #10 on: November 01, 2011 - 04:31:10 PM »
Tman I will get some pictures tonight or tomorrow of the pins.
 I do not know where is that ecu came from. It was on the car when I got it. I have only had the car about 2 years.
Offline Tonefiend
  • '70 Challenger
    • Ian A. Guitars
« Reply #11 on: November 02, 2011 - 03:12:26 PM »
Here are some current pictures. I do have a 4 pin ecu.
 I can't figure out how to Grab the image location of the picture with this phone computer So here is a link to the album.
 http://m.flickr.com/#/photos/72593510@N00/
Offline tman
« Reply #12 on: November 02, 2011 - 03:55:22 PM »
There's your answer, you only need a 2 prong ballast, so wire it for a 2 prong.  That should settle your dilemna.
Offline Tonefiend
  • '70 Challenger
    • Ian A. Guitars
« Reply #13 on: November 02, 2011 - 04:05:33 PM »
Thanks guys while I am at it I am going to run my electric choke of the fuse panel as well.
« Reply #14 on: November 02, 2011 - 07:41:43 PM »
you can run the electric choke to the blue feed wire at the ballast
