Author Topic: Super sucker.  (Read 966 times)
Offline punisher72
  • 70Challenger 440 4 speed yeeehaaaaa!!!!!!!
Super sucker.
« on: November 01, 2011 - 06:29:13 PM »
I tried a plastic 2" quick fuel super sucker recently,and I gained almost .2 of a sec down the 1/4 mile :)
Has anybody had that sought of succes and is there a difference between brands?
I'm told the alloy 1 is for street and plastic is for the strip.
Offline Locomotion
  • IHRA Stock/Footbrake ET
    • Locomotion Racing
Re: Super sucker.
« Reply #1 on: November 05, 2011 - 05:55:29 PM »
Just my opinion, but if you gained 2 tenths with nothing more than adding a Super Sucker, your original carb tune-up was off, probably rich on the jetting and/or the accellerator pump circuit. The many weather variables can also make quite a bit of difference from one day to the next - temperature, humidity, barometer, breezes, etc.
I haven't done back-to-back testing to see how much it helped in my particular combination, but I am a believer in spacers and use a 1" version by Canton. I switched from a 4-hole to the tapoered 4-hole, so the difference would have been less than going from no spacer at all. But any such changes affect the carb and can require retuning to "re-optimize" it - if it was just right to begin with.
Aliminum is more durable than plastic, but transfers heat a little more. Plastic is a better insulator but can warp from too much heat. The Canton version I use looks like machined plywood or particle board. Forgot if they call it "phenolic" or something else.
Offline punisher72
Re: Super sucker.
« Reply #2 on: November 09, 2011 - 04:01:36 PM »
Hi locomotion. Not sure I agree with the tuning side of things?? I have 2 mates that have had their motors on an engine Dyno and 1 gained 34hp the other gained 40hp just by bolting on a 2" sucker same as what I tried..
I did have to go up a few sizes in jets after as it ran a bit lean.
I appreciate your feedback mate :cheers:
I am surprised no one else has chimed in about this subject???
