Author Topic: Master cylinder and booster color  (Read 1894 times)
Offline lee01
« on: November 02, 2011 - 10:51:51 AM »
I need to redo my brake master and booster, some previous owner painted them body color.
 What was the original color for a 74 Chally?
I'ved seen black booster with steel master, goldish booster and some silver.
As you can see, I can't look any more under my hood, its soooo wrong! lol
Current Project
73 'Cuda 360
Re: Master cylinder and booster color
« Reply #1 on: November 02, 2011 - 11:25:39 AM »
You have the Midland Ross booster.(banded) Those were zinc dichromate plated.(the yellow/gold plating)  The master itself was left bare metal.  The finish on the cover is being debated.  Some came bare metal(maybe phosphated) others came zinc dichromate plated.
Some cars came with a Bendix booster that has the two halves crimped together.  Those were painted black.
Offline lee01
« Reply #2 on: November 02, 2011 - 11:41:59 AM »
Thank for ther info. I  know what a  Midland Ross booster is!
Do you guys think if I try to use paint stripper to take that paint off, what are the chance to bring the zinc finish back?
*edit* After decoding my fender tags.....my car come with manual brake..... so its not original, but I will try to get it back to a factory finish
Current Project
73 'Cuda 360
« Reply #3 on: November 02, 2011 - 12:29:15 PM »
It's highly doubtful that the original plating is still in good shape.  Painting the booster to look like the correct plating never turns out looking right.IMO
You have two options.  You can send the booster to Booster Dewey for a rebuild and replate...or you can just paint it black.  If you paint it, you can fill/sand all the pitting out of the case.  If you have it replated, you have to live with any pitting that is present.
Offline lee01
« Reply #4 on: November 02, 2011 - 12:37:34 PM »
I won't send it for a rebuilt since everthing work fine.
I will strip them this winter and see what condition they are in opnce totaly stripped.
If I go black on the booster, what finish would be correct, high gloss, semi-gloss, dull?
And in 1974, any inpection sticker or label was on those booster?
Current Project
73 'Cuda 360
« Reply #5 on: November 02, 2011 - 12:45:40 PM »
You could try separating the halves and sending the pieces out to be replated yourself.
In 1970 the boosters were painted gloss black.  The paint back then wasn't very good and it didn't shine like the gloss black of today.  The paint may dull a little with engine heat so I'd spray it gloss.
Offline lee01
« Reply #6 on: November 02, 2011 - 03:19:34 PM »
You must be in Canada :canada: as i see the Eliminator Battery from Canadian Tire :lol2:
Just paint the Booster Black if everything works fine, your motor is not a stock set up so you can do what you like and it will look good with the rest of the set up.
Another one jealous of my battery lol  :roflsmiley:  Look cool doesn't it  :bigsmile: with the flame and everything lol
Yes i'm in  :canada:
Current Project
73 'Cuda 360
Offline Husker Cuda
« Reply #7 on: November 03, 2011 - 09:20:35 PM »
Here is my 74 Cuda that I had Booster Dewey restore.  He does great work.
1974 'Cuda 512 stroker 650HP Indy heads, Hemi 4 speed, pistol grip - restored to new.
1970 GTX 440/727 Y4 Gold w/ black interior
1969 Camaro SS 396 4-speed X22
1970 Chevelle SS 396 - 375HP M22 4 speed
