Author Topic: Best oil pan gasket?  (Read 3940 times)
« on: November 07, 2011 - 07:35:13 PM »
I'm building a 451" and was wondering about oil pan gaskets? Does anyone have a molded silicon rubber type gasket with the steel inserts for the bolts ( so you can't over tighten it?) Used lots of this type of gasket in SBC engines but don't know where to get one for a BB Mopar?
I'll be using the Milodon road race pan if that matters?
Same design valve cover gaskets would be good too if anyone knows of any?
Re: Best oil pan gasket?
« Reply #1 on: November 07, 2011 - 07:44:51 PM »
FelPro has a premium oil pan gasket , I guess I should have included it with the pan , I think it is $60 or so , you may need two & I would install a crank scraper as well
« Reply #2 on: November 07, 2011 - 07:47:53 PM »
Would you happen to know the part #?
Would this be useful? Or will Milodon have a crank scraper?
http://www.ebay.com/itm/390361507888?_trksid=p3984.m1423.l2649&item=390361507888&viewitem=&sspagename=STRK:MEWAX:IT&vxp=mtr
« Reply #4 on: November 07, 2011 - 08:32:34 PM »
looks like the right gasket , I would just make a crank scraper out of cardboard as a template & weld it onto a windage tray
 yes the windge tray is helpful as well
« Last Edit: November 07, 2011 - 10:44:12 PM by Chryco Psycho »
Offline 72cudamaan
« Reply #5 on: November 07, 2011 - 08:40:32 PM »
looks like the right gasket , I would just make a crank scraper out of cardboard & weld it onto a windage tray
A little too much rootbeer for ya Neil?  :roflsmiley: Weld a cardboard scraper to
the windage tray? You crack me up sometimes.  Though yes, I know what you meant.
If I cant fix it, it's broke
Andy  (phukker whither)
« Reply #6 on: November 07, 2011 - 10:45:00 PM »
special cardbaord that resist oil & can be welded  :smilielol:
Offline Cooter
    • christinecarclub.com
« Reply #7 on: November 08, 2011 - 06:42:12 AM »
Best pan gasket that I have ever used is Silcone.
