Author Topic: later model ECU  (Read 673 times)
later model ECU
« on: November 09, 2011 - 10:36:01 AM »
I just found the original ECU from a 76 Charger I parted out.  The Charger was a 360 2-barrel car.  The ECU is a 5 pin and looks exactly like the original unit from my Challenger.  The only difference is the part number on the housing.  Can I assume that the 73 part number was just superseded and this ECU is OK to use on my 318?
None of the aftermarked units look the same.  I can clean this one up and repaint it.  Thanks
Offline BIGSHCLUNK
Re: later model ECU
« Reply #1 on: November 09, 2011 - 01:29:57 PM »
It will interchange w your 73.  :thumbsup:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline PlumCraZRT
Re: later model ECU
« Reply #2 on: November 14, 2011 - 03:52:18 AM »
As long as the pin-count is the same, they will interchange.
mmmmm.... Mopar.... *drool*
Re: later model ECU
« Reply #3 on: November 14, 2011 - 07:36:56 AM »
later ECUs should be 4 pin so even the pin count will not matter if the car is wired for 5
Re: later model ECU
« Reply #4 on: November 14, 2011 - 09:16:56 AM »
This is a 76 model ECU and has 5 pins.  The only thing that looks different is the gold heat sink plate has an extra bevel on it that my original one didn't have.  I stripped the paint off of it and repainted it this weekend.  I ordered a new "Electronic Ignition" sticker for it too.  It worked when I parted out the car.  I hope it still works.  The part number/date code stencils should be done soon too.  If it turns out looking nice I'll post a picture of it.
Thanks for the help.
