Author Topic: waiting 7 years, The restro has finally begun  (Read 47211 times)
Offline dutch
Re: waiting 7 years, The restro has finally begun
« Reply #45 on: September 16, 2014 - 04:21:39 PM »
nice  :2thumbs:   Looks a bit more orange than I would have expected.  Then again,  If you took the same picture a few hrs earlier or later, my opinion would probably chance as much as the color....  :bigsmile:
Can`t wait to see it finished  :bigshades:
*** Bart ***
Offline daaboots
« Reply #46 on: September 17, 2014 - 09:02:07 AM »
Looking great! I really like that yellow color.
« Reply #47 on: September 19, 2014 - 03:05:50 PM »
 :clapping: :woo: :2thumbs:   NICE!!!!
Offline culp71
« Reply #48 on: December 09, 2014 - 02:16:45 PM »
...and continues,
despite the cold, I forge ahead..
Front K member, upper and lower control arms, ball joints, support rods, torsion rods, tie rods, rear differential, leaf springs, hubs, all reworked/ rebuilt, new bushings, blasted and painted and mounted.
It is finally sitting on the ground, on its own tires.
next is to be engine bay and firewall paint, jam and inside shell paint.
all major body components are back on car and adjusting /sanding for those "perfect" body lines.
decided to leave 4 drum brakes, as plenty of stopping power, plus no matter what disc and pad material used, it seems to destroy rims very quickly.
« Last Edit: June 08, 2016 - 12:37:32 PM by culp71 »
Offline culp71
« Reply #49 on: March 13, 2015 - 12:40:08 PM »
so it is nice out once again and this should be the year for body Completion!!
I have seam sealed all inside body joints, filled, and rough sanded engine bay, inside body shell, and trunk area.
Also begun engine rebuild and planning on painting the engine bay and body inside very soon!
« Last Edit: June 08, 2016 - 12:38:32 PM by culp71 »
Offline roadman5312
« Reply #50 on: March 13, 2015 - 12:44:28 PM »
Lookin good   :2thumbs:
Offline culp71
« Reply #51 on: April 30, 2015 - 01:23:36 PM »
well getting very close to laying paint inside and out, but decided to replace outer rocker panels, as its the only part I have not separated, reworked or replaced, (don't want rust stains appearing out of these in a few years). located a very nice new set , cut off old ones (glad I did) blasted, etched sealed and painted then installed new outers. they fit and looks great, and no rust!
got AAR fiberglass front bumper and modified it to reflect the 71 elastomeric version, welded and glassed in steel support in bumper to bolt to original bumper brackets, killer.
also received 71 correct trunk lid to accept gull wing.
mounted all panels on car and as the wife says "it actually looks like  a car!"
post pics tomorrow.
 :clapping:
« Last Edit: May 04, 2015 - 12:42:35 PM by culp71 »
Offline culp71
« Reply #52 on: May 04, 2015 - 07:44:12 AM »
pics:
front bumper as received
second pic shows after I modified bumper to 71 outline (need to do some light sanding to make perfect)
new driver and pass outer rockers
new trunk lid
pre-new outer rocker, blasted outside of inner/prep
« Last Edit: May 04, 2015 - 12:43:47 PM by culp71 »
Offline Dr. Feelgood
  • 1970 Challenger R/T #XXX666
« Reply #53 on: May 05, 2015 - 12:21:00 PM »
Woah!! Great work!!
What kind of painting set up do you have?
Offline culp71
« Reply #54 on: May 13, 2015 - 08:50:27 AM »
sent PM to Dr. Feelgood
another nice day allowed for some nice painting!!
inside body shell and trunk done.
next will be engine bay, then jams and outside body!!
:bananasmi
« Last Edit: June 08, 2016 - 12:39:57 PM by culp71 »
Offline Ifixmycarmyself
« Reply #55 on: May 13, 2015 - 04:41:10 PM »
Really nice work and thanks for all the pics! planning to paint trunk area this weekend. Which primer did you use. I bought etching, and epoxy primer but can't decide which to use. :clueless:
Offline anlauto
« Reply #56 on: May 13, 2015 - 05:11:16 PM »
What colour is that ?
Offline 70cudageorge
« Reply #57 on: May 14, 2015 - 10:40:40 PM »
Looks awesome, great determination on your project. Love the color. George :bigsmile:
Offline culp71
« Reply #58 on: May 26, 2015 - 09:17:06 AM »
weather was perfect on Friday, so I laid some more paint, engine bay and misc parts...
« Last Edit: May 27, 2015 - 08:37:37 AM by culp71 »
Offline culp71
« Reply #59 on: June 02, 2015 - 09:51:54 AM »
some more painting action!!
under side hood, trunk lid, door hinges, door shells, trunk torsion rods, also undercoated inner front fenders, front and rear valances.
 :bananasmi
